Question about Sony DAV-S500 System
DVD's not playing
On a dva s500 disks not playing lens cleaned no improvement. Disks spinns up but reports no disk found.Where can i get spare parts in Dublin.
  • Sony Master
  • 5,444 Answers
Sounds like the lazer/ lens damage. Try looking at the lens with a magnifiying glass, to see if you can see a chip/scratch.
The Sony UK website has a list of part supply places.
Posted on Jul 02, 2009
My RCA RTD317 has problems recognizing most DVD movie disks. It will play some disks most of the time and all audio disks, so I figure the lasers are working. What could be the problem?
If you've tried cleaning the Laser with a Lens Cleaner Disk or directly with Lens Cleaner Fluid and a QTip without any improvement then the Laser is Failing.
It takes less power to read some DVDs than others and a lot less power to read an Audio CD. The Laser will continue to deteriorate until it won't play anything.
May 08, 2011 | RCA RTD317 Theater System
Doesn't recognize disks anymore
i would try lens cleaning cd 1st ok might be dirty lens just cant read it if not that try firmware update to the unit thx nick
Feb 04, 2008 | Lite On LVW-5005 DVD Recorder
My Toshiba SD-2715 dvd player periodically stops playing and turns off. This usually occurs after 1 hour of play. This has happened with multiple disks, and I have tried cleaning them with no improvement....
Try cleaning the lens, also the inside of the player in and around the disk tray is probably full of dirt, dust etc, carefully try cleanig all that out, you may need to disassemble a bit to get at everything
Aug 22, 2009 | Televison & Video
VCR will play, DVD returns disk with"check disk"-will not accept
Dirty or defective laser lens. try manual cleaning of the lens if you know how to open the unit top cover. manually clean the lens using cotton swab gently rubbing it in circular motion. blowing of air to remove dust will not really help clean the lens.
Jan 03, 2009 | Samsung DVD-V4600 DVD Player/VCR
Dvd disc won't play
Maybe the laser lens are dirty and need to be cleaned
Nov 04, 2008 | Samsung DVD-V5500 DVD Player/VCR
LG DVD RECORDER MODEL DV7711P
I have had this on a number of other players. First try the disks in question on another DVD player after giving them a thorough clean. If they work there then you know the problem is not with the disks.
After that (assuming the RH299 is actually working in every other respect e.g. on HDD), run a laser cleaning DVD/CD in the machine to clean the laser lens. If your machine is out of warranty then you can try opening it and cleaning the laser lens with rectified spirits/pure alcohol. Then try the disks again. If they still don't play, then it's off to a local electronics expert to see if realigning or replacing the laser and transport mechanism is economically viable, or buy a new machine.
Jun 30, 2008 | LG RH299 DVD Recorder/VCR
Bad disc, lens cleaner doesn't work
Even tho it came up as a bad disk the brushes would have cleaned your lens as it tried to play the disc. If theres no improvement after using the cleaner you may need to take the unit to an engineer. Is it reporting every disk as bad or just a few??
Apr 03, 2008 | Cyberhome CH-DVD 300 DVD Player
No disk message
i have the same problem
Oct 12, 2007 | iLO DVDR05 DVD Recorder
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Sony DAV-S500 System Logo
395 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
