Question about LG Washing Machines
I need the manual for the WF-T1391tP Machine. Don't know how to use the machine on a hot wash. Cold water fill.
    Brigadier General:
  • 3,614 Answers
Go HERE
Posted on Jul 02, 2009
  • micromaster
    micromaster Jul 02, 2009
    • does the manual not work with you??
  • Anonymous Apr 05, 2017
    Hi , I have a WF-T1391TP LG washing machine and the manual that I downloaded cannot provide me from page 15, please help!!!
LG WF-T653a - The cold water only dribbles out when trying to fill the tub, (the hot water comes out fast) which causes an IE error constantly stopping the machine. Any ideas what I can do, please?
You may need a new inlet water solenoid. But first check the small gauze filter in the cold water inlet connection. They can get blocked.
May 28, 2018 | LG Washing Machines
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
The Tub Clean function never ends
why do you use tub clean function, we have never had the need to reclean the tub having just run hot detergent and water thru it .
Oct 04, 2015 | LG WM Washing Machines
I have a LG WF-T753A washing machine. The hot water is not working, but has in the past - cold water is fine. When it goes to fill up with Hot only, a slight hum, and then it stops, but no water. Have...
Check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
May 04, 2011 | LG WFT1071TP Top Load Washer
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
The wm does not accept cold water. I put it on cold cycle and it does not work the water line is fine... what could be the problem ?
Why has nobody mentioned the fact that if you “draw off” hot water using a tap beside the washing machine you can get “instant” hot water to your hot-fill. I have been doing this for years – now that all my hot water is heated by a crabon-neutral energy source (either wood or solar) I feel it is even more energy efficient.
As for water consumption, my house has a secondary return pipe on the hot water circuit with a temperature sensor fitted to the pump so that it only switches on when you turn a hot water tap on – you than turn the tap off, wait 5-10 minutes while the water circulates, then turn it on again, by which time the hot water only has ashort distance to travel and you don’t waster much down the drain.
However, I have been interested to read about the pros of cold fill only, especially the arguments about such a small volume of water being used anyway and the possibly improved wash performance? Also, I was dismayed to read that washing machines with hot and cold fill don’t use the hot wate very efficiently.
So would I be better off going for a hot and cold machine while they’re still available or going for a high-efficiency cold fill only machine? I am still minded to get an LG with hot and cold fill… comments please?
Dec 04, 2009 | Washing Machines
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Users manual
The LG Canada website has it.
http://ca.lgservice.com/index_b2c.jsp
Click on "Owner's Manuals" on the left hand menu and fill in the details, model number WF-T8016TP. You'll need IE, not Firefox...
Jan 24, 2009 | LG WFT1071TP Top Load Washer
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
216 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
