Connect portable dvd player,good picture in black & white,but should be in colour
  • 3 Answers
Must verify color sistem (pal. ntsc.secam)in menu
Posted on Jul 02, 2009
DVD Playback is only Black & White
Different areas use different colour systems. The most common types being PAL and NTSC. What I think you might have done is changed the colour type setting to one that is not compatible with your TV. If you have the manual look up the colour settings. If you haven't got the manual look around the main menu for them. If all else fails use the factory reset.
Mar 12, 2017 | Toshiba Bdx1200 Blu-ray Disc Player
Hi the picture on our portable dvd (United DVP9042) player has gone from being in colour to black and white & I can't seem to change it ..... some of the words eg 'dvd' or 'av...
The unit has a color controller PC board that switches between BW and Color. The fact that you still show color at all indicates the circuit is complete and the BW exists independently by itself. In some cases, the problem is due to connecting cables. Change out the current set and see if that presents a solution. Make certain all connections are firm and tight. Other than that, internal data switches pose a problem and the circuit needs to be traced using test equipment to locate the problem.
Feb 05, 2018 | Audio Players & Recorders
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Portable DVD showing blue screen
i have the same dvd player the pink 1 i lent on a button and it went into black and white i have tried everything and can't seem to get it back into colour again, ive tried pressing all the buttons and nothing seems to work or come up with any black and white/ colour options :(
Mar 04, 2008 | Televison & Video
DVD works but the screen is black and white
Precorded discs, or copies made on a computer? Other than that, getting service will take a miracle, as the company is out of business...accordianman
Jan 02, 2008 | Cyberhome CH-LDV 700B Portable DVD Player
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Black and White on TV
europe uses PAL and not NTSC..change the setting on the TV or DVD player accordingly. Set the TV system to NTSC or the DVD system to PAL
Nov 09, 2007 | Audiovox D1708 Portable DVD Player
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
