Question about Creative Labs Inspire P5800 Computer Speakers
Well my center speeker is not working but the rest are ok the speeker is ok but no sound . all the wires are pluged ...what can i do?
  • 60 Answers
Do they use a jack plug the same size as a pair of headphones would? if so try plugging them into a radio or CD player to test that the speakers work, if you still dont get sound and your sure the volume and any other switches are in the correct possitions then you will know it is a fault with your speakers, if they do work then there is a fault with your computer outputting sound.
Posted on Jul 02, 2009
INTERNAL SPEEKERS do not work external speekers work when pluged in
Check the menu. In almost flat panel tvs there is setting that allow you to select in between internal speaker and external speaker. If the selected setting is external speaker the you wont get sound from the internal speakers.
www.electro-medical.blogspot.com
Sep 01, 2015 | LG 55GA6400 55" LED TV 1920x1080, 120 Hz,...
97 DODGE 1500 CHASIS WIREING DIAGRAM
probably a bad ground connection on the speaker. remove door penal and speeker and inspect.
Mar 24, 2013 | Cars & Trucks
Internal speakers produce no sound
If you're sure the speekers work, it may be ether cause the there is something loose or not conected inside. There is a small posibility that maibe the dvd player doesn't have the right drive or none at all, but if it works with headfones then it's more likely that the speeker is busted so you'd have to replace it. Best thing to do is open it up and look at it and it's conections. See if anything is loose or looks a bit scorched. If everything looks ok, you could try hooking the speeker to something else to make sure they work.
Sep 30, 2011 | Televison & Video
I purchased a set of Logitech LS21 speekers and I can' get them to work. Below is a list of my system hardware and the steps I have done so far. Motherboard is a Gigabyte GA-MA785GM-US2H 16GB RAM AMD...
Go into control panel, then go to device manager and see Audio devices. Check to see if your Realtek is listed as your default audio device. If it isn't you have to add hardware and add the audio device using your setup disk that should of came with the computer. If the audio device is set up and working in device manager then check your cable from the mother board to the jack on the audio out that is mounted on the mother board. Finally if non of that works see if you can borrow a set of speakers to try to see if they work with your setup.
Mar 07, 2011 | Logitech LS-21 2.1 Speakers
I cant hear any sound from my speakers What can I do to make them work again
ok if there has been change in the hardware then its a software issue try 1 reistalling the driver for sound (unistall the old one first) 2 go into the sounds and see if there all at the corrct settings 3see if any wires of the speekers have come loss push them all in a bit 4 get a program to checkm your drivers like driver pro hope some of this helps
Mar 18, 2010 | Audio Players & Recorders
Hi I had a problem in sound I have a PC that have M2N-MX motherbord And I had install windows 7 And I update the windows to update the drivers ao, all the PC is work perfectly exept the sound the driver is...
ok reinstall your driver cd's if you have a sound card it soud be pluged in tere if not on the motherbord but anyway do not upgrade from the internet makes your pc slow and plug it into the back not the side.HOPE I WAS USEFULL PLZZZZ PLZZZZ PLZZZZ RATE ME I WAS WILLING TO HELP YOU AND SORRY FOR MY SPELLING I AM ONLY 13 AND AFRIKAANS AND IF THERE IS ANY PROBLEMS WITH YOUR MOTHERBORD,PS1,2,3,DVD PLAYERS,XBOX AND PC STUFF PLZZZ EMAIL ME TO markusmaritz@yahoo.com i know you thing i am a little to younk but no i just know all this stuff i do not know but plzz rate me thanks.
Nov 01, 2009 | ASUS M2N-MX Motherboard
Speekers no sound
Sounds to me like the amp needs power. Is it usb powered? or have a wall plug?
Oct 28, 2009 | Boston Acoustics BA735 Computer Speakers
I have a 2000 Z3 and there is a thump that comes from the speaker
Check to see if at the amp there is a strand of wire crossing over. i had a friend onetime who had the same problem and they just didn't twist the wire all the way before connecting it.
Aug 20, 2009 | Car Audio & Video
There is a short buzzing sound from the rear left speeker then CD failure shows up on the display and no sound is produced .Model Sony CDX-GT470U I have wired it up according to the instructions and can't...
The problem was that one of the speeker terminal wires was touching the metal body
of the car on the edege of the hole where the speeker magnet sits.
Once I moved the bare wire a little it fixed the problem.
It's the little wire on the speeker itself not the wire that runs to the player.
Dec 09, 2008 | Audio Players & Recorders
Speekers
hello
okay i think your base is too full.
turn off the base of your speekers and then try to play a song or a sound...
if not go to control panel and then sounds and lower down the base volume bar
Dec 10, 2007 | Audio Players & Recorders
Creative Labs Inspire P5800 Computer Speakers Logo
149 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
