Question about Canon PIXMA MP160 All-In-One InkJet Printer
Changed the ink cartridge when i turn it on i get e 2 and alarm
    Problem Solver:
  • 24 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq8
Posted on Sep 05, 2009
    President:
  • 2,306 Answers
E2 just says load paper and press continue, sounds like it wants to print with the new ink and just needs paper.
Posted on Jul 02, 2009
3 Suggested Answers
SOURCE: Alarm light on, Display indicates error message: Check Ink U150 M
I just had the error message V130 - check ink cartridge. I held down the stop/reset button for about 5-10 seconds and the problem was solved!
Posted on Apr 12, 2008
taran_2005
  • 10515 Answers
SOURCE: Changed black ink cartridge. Closed machine up.
I am sorry, however this error is no related to print head. So, why did you replace print head?
This error means "Ink Detection Waste Ink Tank Full"
You need to replace the ink pad and reset the eeprom counter to 0.
You could try to reset it :-
1. Printer ‘on.’
2. Press: “Additional Functions” button
Press “Scan” button
Press “Copy” button
Press “Scan” button
3. Now it says, “Service Mode / #1 SSSW.
4. Keep hitting “+” [which is the right arrow]; it will go through #1 to #11 (Date/Time), then “Service Report,” and, lastly, “Test Mode.” Then hit “Set.”
5. Now you will have another set of selections. Keep hitting “+” [the right arrow] to go from #1(DRAM) to #8 (Printer Test). Then hit “Set.”
6. When it finishes some sort of function, “Please Wait” will be replaced by “-8-2+” Then hit “+” and it should then say “-8-3+” and you hit “Set.”
7. The screen should now say “EEPROM Clear.” [You may need to press “Set” then, to get to the next step? My notes aren’t clear.]
8. Option 0 should be “select ink count.” Press “Set.”
9. Press the “Stop/Reset” button.
10. Press the “On/Off” button.
11. Wait for the printer to restart.
You could have the complete service manual from :-
http://soft-manufaktura.ru/manual/hp/mp390sm.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 09, 2010
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    Alarm message says "cartridge jammed". Does that
    What you see moving is the print carriage. The carriage moves the cartridge, adjacent to the printhead, back and forth.
    Although the carriage is moving, the ink cartridge can not dispense ink because an obstruction is
    blocking the path of the ink.
    Remove the ink cartridges, inspect the cartridges as well as the cartridge holders for any foreign debris and reinstall.
    If the alarm message continues, I suggest changing the ink cartridges.
    Feb 17, 2011 | Canon MultiPASS F50 All-In-One InkJet...
    I replaced the color ink cartridge. Now there is an "E" flashing alternately with a "5". The alarm light is on steadily, and the black ink and color ink lights are flashing. How do I...
    E5 is a Cartridge cannot be recognized error.
    Reinstalling the cartridge could clear the alarm.
    If this does not work,
    Removed both ink cartridges.
    Turn off printer and unplug fron electrical outlet.
    Wait at least 5 minutes.
    This will let the printer reset itself.
    Plug printer back in and turn on.
    Printer will cycle and an E5 will appear.
    Installed back ink cartridges.
    Jan 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
    I only want to scan but need a new cartridge - do i have to replace cartridge before scanning is enabled.
    You will need a new cartridge before you can scan.
    What you could try is to remove both ink cartridges.
    Turn printer off and unplug from outlet.
    Wait at least 30 minutes, this will let the printer to reset
    Turn your ink cartridge upside down for 2 minutes before installing.
    This will let some of the ink from the bottom to reach the printhead.
    Plug printer back in and turn on and install ink cartridges.
    This might work if your printer only detected a low ink condition at first.
    For the scanner to work, the printer must have no alarm.
    Jan 14, 2011 | HP PSC 1315 All-In-One InkJet Printer
    Alarm lights keep blinking after I changed my printer ink.
    E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
    You can also try this:
    1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
    (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
    Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
    alternately, Alarm in orange and Power in green, starting with Alarm LED.)
    4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
    Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
    4 times----Green (Power)------Waste ink counter resetting
    Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
    My canon pixma 180 has orange alarm light and reads check ink cartridge,. it won't print. it printed yesterday.
    One or both print cartridges are defective.Look under the "check ink" what message come.If it's BLK change black cartridge, if it's CLR change the color cartridge.If BLK and CLR change both cartridges.
    Nov 05, 2009 | Canon PIXMA MP180 All-In-One InkJet...
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    I CHANGED MY PIXMA INK CARTRIDGE AND HOW TO RESTART?
    Here's what you can do....
    METHOD #1 - Easiest, but it disables the ink tank level indicators.
    1) Ignore the low ink indicator, and press the RESET BUTTON to continue printing. If you press and hold the reset button for 5+ seconds, it will disable the counter for that particular ink tank. Refill tank now.
    2) Repeat as needed.
    You will get a dire warning that this will void you warranty, blah blah blah. If you do need to take your printer in during warranty and you've disabled ink tank counting, simple reset the entire printer as describe below for the wate tank warning, and nobody will ever know. SAVE YOUR CANON CARTS with a bit of ink left in- your printer will need to have Canon carts installed for warranty service.
    3) Eventually you may be warned that the tank is empty. Press reset as above to disable and continue printing.
    If you think this entire thing is ridiculous- you are right.
    Get an earlier model that takes un-chip carts, like an ip6000, or ip3000, or i960. Much simpler and you get to use the ink tank indicators after refilling.
    You can reset the entire printer with the WASTE TANK reset (below) when you need to clean or change the waste tank PAD (its really not a tank) See the above instructions for the i960 and similar for other Canon printer waste tank changes.
    Here's the ip4200 reset options:
    1) With the printer power turned off, while pressing
    button. (DO NOT release the buttons. The Power LED
    selectable.)
    resume/Cancel button. (DO NOT release the Power
    button.)
    the Power and Resume/Cancel buttons. (Each time the
    time(s)
    setting).
    Time(s) LED indication Function Remarks
    0 times Green (Power) Power off When the print head is
    not installed, the carriage returns and locks in the
    home position capped.
    1 time Orange (Alarm) Service test print .
    2 times Green (Power) EEPROM information print
    3 times Orange (Alarm) EEPROM initialization
    4 times Green (Power) Waste ink counter resetting
    5 times Orange (Alarm) Destination settings After
    entering the destination settings mode, press the
    to select the destination. For detail, see
    "Destination settings procedures" below.
    6 times Green (Power) Print head deep cleaning
    (Cleaning of both black and color)
    7 times Orange (Alarm) Reserved
    8 times Green (Power) CD / DVD check pattern
    9 times Orange (Alarm) CD / DVD print position
    correction (horizontal: X direction)
    10 times Green (Power) CD / DVD print position
    correction (vertical: Y direction)
    11 to 13 times Orange, Green, Orange(Alarm,
    Power,Alarm) Return to the menu selection
    14 times Green (Power) Left margin correction Not used
    in servicing.
    15 times Orange (Alarm) Return to the menu selection
    Nov 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
    Printer Problem
    This was not the sollution for my pinter..
    My Magneta is half full and my error led is also blinking 15 times
    I found this service manual for the IP4200 but this methode also doen not solve my error led..
    Is their someone who has the sollution for this strange error?
    selectable.)
    button.)
    Power
    in
    time(s)
    setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
    >>>>>>>>THIS ONE
    4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
    in servicing.
    Time(s) LED indication Destination CD / DVD print
    0 times Green (Power) No change of the destination
    1 time Orange (Alarm) Japan Supported
    2 times Green (Power) Korea Not supported
    3 times Orange (Alarm) US Not supported
    4 times Green (Power) Europe Supported
    5 times Orange (Alarm) Australia Supported
    Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
    Canon PIXMA  MP160 All-In-One InkJet Printer Logo
    80 people viewed this question
    old marine
    old marine
