Question about Lanier Office Equipment & Supplies
Print willnot show exept at bottom of page have changed toner
  • 541 Answers
Your printout is only 1/2 the page than your image may not be developed or transfered. you will need to remove the deveolper unit and look at the front of it. does the devolper go all the way across the front of it?
Posted on Oct 05, 2009
Why do I have yellow horizonal lines on printed page
Sounds like a faulty toner cartridge. Are all the cartridges OEM?
Jun 16, 2017 | Brother Hl3070cw Hl-3070cw Color Laser...
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
I am getting a blank stripe top to bottom on every printed page
You write "I am getting a blank stripe top to bottom on every printed page". You didn't say copy or scanned pages. Change the toner cartridge.
Feb 04, 2011 | HP LaserJet 3050 All-In-One Printer
My Brother HL2140 printer was running fine and all of a sudden the toner light is on and it stopped printing. Just yesterday when i printed out the status for the drum and toner it showed more than 80 %...
636 is a lot of pages and depends on the toner coverage you may need to replace the toner.. 80 - 75% (is that used is remaining ??) any way check your waste toner basket first (see you manual for instructions) chances are its filled and needs cleaning or replacing (see your manual for instructions) If its fine then change your toner .. If you have the demo toner (toner shipped with machine) these contain less toner than a new cartridge and will finish faster ...
Jul 26, 2010 | Brother HL 2140 Laser Printer
Is there a override function to keep printing when toner alerts are on?Wondering since black still shows 30%.
These printers will still print when any or all of the toners are LOW, but if any one of them is EMPTY (according to the chip on the toner cartridge) printing stops.
Standard capacity toners ere 2000 page for the colours, and 3000 page for the black, so they can soon be used up.
Much cheaper per page printed, if you use the high capacity cartridges (6000 page for the colours, and 8000 page black).
There are high quality remanufactured cartridges available now, as good as OEM, and typically you'll get a Hi Capacity Remanufactured cartridge for the same sort of price as a Std Capacity OEM cartridge.
As a short term solution at a lower cost than replacement cartridges, you could just replace the cartridge CHIP. The printer would then think the toner was full (there'll likely to still be some toner in it), so you'll be able to print. Don't run the printer like this for ever though, as the toner has some lubricant properties, and with a TRULY EMPTY cartridge, you'll eventually do some damage to the cartridge, and then possibly the transfer belt (and you don't want to be changing that until it's rated 100,000 page life is up.
May 01, 2009 | Xerox Phaser™ 6180DN Laser Printer
Printer smears on cold print
The toner cartridge sounds like the problem to me. Did you refill it? Or have it done? It sounds like an incompatible brand......toner is very model specific, and not just 'any' will do, and it often doen't mix well with the remaining toner i the cartridge if it is not completely disassembled and cleaned out. Just curious
Mar 16, 2009 | Brother HL 5250DN Laser Printer
My 5316 copier keeps blinking F2 and willnot print I have changed my developer still it keeps showing F2
F2 - Black toner supply trouble
Try a different toner cart, remember to shake the cart. before installing. Power the machine on and off and check. Check the sealing tape has been fully removed from the cartridge as well as the green colored plug.
Also, if you have an original drum unit frame, change the frame with the new Modified version to prevent arching at the rear cover of the drum unit against the inside back plate of the machine.
Check that the black dev. tank is not low or empty, re-position both drum & dev. tank.
Pls rate - Thank you
Mar 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
MFC-7420 GHOST IMAGES
sounds like a bad drumbur also can be caused by a defective fuser.
Jan 16, 2009 | HP LaserJet 1020 Printer
24 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
