Question about Refrigerators
The fridge will close but you have to pushed
The fridge will close, but it has to be pushed firmly and then when it is closed there is not sufficient suction and can be easily opened. The seals look ok but the one across the top of the door is not as thick as the side ones. There are 4 hinges on the door, the bottom two  have a piece of plastic between the side of the hinge and door, has this any relevance to the problem
    Problem Solver:
  • 5 Answers
Ya do change the Plastic In Between between the Hinge and the Door .If it Doesnt work try looking at the Hinges they Might Be loose
Posted on Jul 02, 2009
Whirlpool double door fridge. Door wont stay closed. Have to push extra hard to keep it closed
Take out the shelves and drawers. check the rear is clear of ice before putting them back in place, and ensure they are not stopping the door closing. Next check the top and bottom of the door. Is it hitting the frame when closing? If so, straighten it up by tapping the hinge side of the door to make it square to the frame.
Jul 04, 2015 | Whirlpool Refrigerators
Fridge door does not stay closed
"fridge door does not stay closed" (sic) This can happen if the door magnet has lost it's grip, this can be easily replaced, either DIY, or there are many firms that offer this service. Or the latch mechanism isn't working as it should.
if you wish to DIY then first obtain a service manual, for your exact make and model. This shows you what to do & how to do it, also more importantly it has parts numbers too.
Nov 15, 2010 | Microwave Ovens
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
Door on my samsung frig' will creep open
The fridge needs to have a slight tilt back so the door will close with ease!! also check and clean the door gaskets and metal surface that the gasket touches when the door is closed because there is a magnet inside the gasket and it will make a nice tight seal if all the surfaces are clean.If the gasket is torn it should be replaced
Nov 06, 2009 | Refrigerators
What is the light switch button for in the fridge section? why does the light stay on in the fridge with the door closed when the switch inside is on ?
The switch is curved so when you close the door the light will also close.How do you know if the light is on when the door closes?Try pushing on the switch and you will see that the light will close.If that is what you are asking.If you push on the switch and the light stays on then you have a faulty switch. hope this helped:)
May 11, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
Mar 16, 2009 | Refrigerators
Freezer doors opens slitghly every time we open the fridge. The suction for the freezer seems too low to keep it closed firmly.
Hi thanks for the question. tilt the fridge back . Unscrew the legs, so that the fridge is now higher . this will make the doors heavier . and will close better . thanks the appliance doc
Oct 06, 2008 | Maytag Refrigerators
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Refrigerator door
TRY ALIGHNING THE DOORS.I HAD ONE CLIENT THAT I HAD TO ALIGHN THE DOOR UPWARDS BECAUSE THE DOOR WAS TOUCHING THE BOTTTOM OF THE FRIDGE ON THE INSIDE.
Feb 19, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
