Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
Display Problem I have same Probelm like no display with gray color screen. i tried by changing the RAM but no success. but i got the display with external monitor. Can you please discribe the reason and solution if you have any. Thanks in Advance.
  • 60 Answers
I assume this is a laptop? the problem with laptop screens are the thin ribbon that they use to connect to the motherboard, on some laptops this is very close to the hing and after long use can become frail which breaks the data busses. Without actually seeing your laptop i could not give you a definiate answer but i would bet on your ribbon being damaged, these can be very cheep to find on ebay. It will take some skill to replace the wire though as you will have to dismantle the laptop case to get to the back of the screen, if you are not experienced in this i suggest taking your laptop to your local computer repair centre.
Posted on Jul 02, 2009
  • 3 Answers
Digitizer needs replacement
MY DISPLAY SCREEN DONT DISPLAY ANY COLOR AND WHEN IT DOES IT LOOKS LIKE A NEGATIVE. WANT TO FACTORY RESET BACK TO DEFAULT.
Hi
hope you have fixed the problem by now.
But in case you can try resetting the parameter ram by simultaneously pressing the Option - Command - P - R keys. All four at the same time.
Turn on your Mac and immediately press and hold the Option-Command - P - R keys. You must press the keys before the gray screen appears. Continue to hold the keys until the computer restarts, and you hear the startup sound a second time.
Hope this helps
Aug 15, 2013 | Computers & Internet
Display probelm
After reading your issue,i am sure that there is problem with your motherboard.
as you cannot see anything on screen and you get power,that means your motherboard is faulty
so just get your motherboard replaced and it will be fine as before
Thanks
Jul 28, 2010 | Intel Desktop Board D845WN Motherboard
Gray display on the screen when install windows xp
your computer does not have enough memory to run windows xp. try upgrading the ram and possibly a bigger hard drive. good luck.
Jul 09, 2010 | IBM ThinkPad T23 2647 Notebook
Hello, please when i put no my sony vaio notebook, the colors are mixed on my screen, i have changed the screen and the screen cable but the problem is still there
Try taking out one ram stick at a time in between boots. It sounds like you make a bad stick of ram and that is causing video issues. Just a thought.
Sep 06, 2009 | Sony VAIO PCG-K25 Notebook
Display
your laptop display mass color, it is not the issue of inverter.
there are two situations:
1) mass color you can not see any messages like letter or picture
2) mass color with some or any messages you can see.
above situations you need to check LCD sreen cable connection between LCD socket and the motherboard socket, plug back properly.if not fixed, there are some tips you may consider:
1) change the Ram if the display ram is not isolated.
2) the LCD cable damage need to change or
3) LCD screen damage need to change or
4) finally the motherboard display chips damage(rare)
May 07, 2009 | HP Compaq Presario V2000 Notebook
Display driver r300
Try reinstalling the video driver or updating it to a newer version.
Drivers and updated drivers can be usually found on the manufacturers website.
http://support.asus.com/
Jan 15, 2009 | Packard Bell Easy One Silver 2120 Notebook
LCD screen displays settings only. Won't take pics
This sounds like a defective CCD that Canon is repairing free. Go here for more details: http://www.imaging-resource.com/badccds.html
Nov 10, 2008 | Canon PowerShot A75 Digital Camera
Colors in QL-711V shifted to green
Hi, I had the same problem and I wrote an email to Nu. They wrote me back that I should use the Factory reset feature which you have to go through the Factory Menu to get to. Instructions to do this are as follows. I got to the menu my first try but it has been a pain to get back to it. I hope it will be easier to access for yours.
Hope this helps
-Nate
Page 1
You will need to display a gray scale picture which varys from black to white
You will need to display a gray scale picture which varys from black to white. Displaymate 16 grays pattern is good or something like the picture to the right. 1 Press and hold SEL/AUTO and press the power button. Then release the SEL/AUTO button. 2 Press the MENU key to display the factory menu. Sencore 11 gray Pattern 3 Press the and select FACTORY2 menu. Factory2 is at the bottom. Press SEL/AUTO to select the FACTORY2 menu. 4 Press the to select AUTO COLOR. 5 Press the to run AUTO COLOR. Wait until finished. You will see the colors changing and then become stable when finished. About 10 seconds. 6 Press the and select COLOR UPDATE. 7 Press the to run COLOR UPDATE. It will finish quickly. < 1second. 8 Press MENU to exit the menu. Power off/on.
Nov 05, 2007 | NuTech QL-711V 17" Flat Panel LCD Monitor
Screen
If you have access to an external monitor, you might want to hook that up to your laptop and try it. If the display looks good on the external monitor (which I would suspect that it will) then, you may have a loose LCD cable, a worn cable or a bad LCD display. Try reseating the connector. With the LCD cover off & power on, carefully wiggle and flex the cable and see if there is any change in the display. If not, your LCD display is probably going bad on you.
Hope the rest of your day goes better!
R-
Nov 02, 2007 | Acer Aspire 3000 Notebook
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
