SOURCE: olds alero 2.4 idle fuel pressure
most likely idle air control sensor or low engine coolant I know sounds funny but IAC uses coolant to regulate idle. Idle air control valve or throttle body positioning sensor.
SOURCE: rough idle after warm up
I'd take a look at the temp sender...the engines computer may be
"thinking" the engine is still cold when it's not. That would cause it
run rich (and rough) after it's warmed up. Generally the sender can be
tested with an ordinary volt/ohmeter but you will need the
specifications available in most inexpensive manuals. As with any
complicated electronics system, I can only give you my best guess,
without the luxury of doing any hands-on testing myself.
Good Luck!!
SOURCE: 91 Jeep wrangler New everything idles rough, no Power then dies
you check for miss how is compression
SOURCE: 2000 gmc starts but then idles rough then dies
I had to replace the mass air flow sensor. $ 150. the engine would shut off when driving too.changed fuel filter only worked for a day. The sensor is just after air filter.
