Question about IBM ThinkPad 600E 2645 Notebook
After start i come to a highlighted image where both OFF and ON are highlighted. Battery has been changed and the only problem now is to get it ok so it may be used again. Hope its possible to get some help on this 1.
I have a Kodak M850 Easy Share hooked up to my television with an mini HDMI cable. The picture shows nicely but I don't know what camera button to use to make a slide show appear on the tv. Can you help?
Starting the slide show
  1. Press the Review button, then press the Menu button.
  2. Move autourg00422004id1197998.jpg to highlight Slide Show [img src="http://resources.kodak.com/support/jpg/en/manuals/GLB_en_urg_00422_images/autourg00422004ID1198002.jpg" alt="">, then press the OK button.
  3. Move autourg00422004id1198023.jpg to highlight your option, then press the OK button.
Mar 18, 2014 | Kodak Cameras
How do I change the size picture it takes ?
While you're in LiveView or Playback, press the MENU/OK button. Use cursor-left/right to highlight the camera symbol. Use cursor-up/down to highlight image quality (mountain with three stars below) and press MENU/OK. Select the desired image size.
The above is from the "Using the Capture Menu" section of the user guide (page 17 in my copy). If you need the guide or other documentation, you can download them from here.
Oct 14, 2011 | Cameras
I am using a Fujifilm FinePix JX250 digital camera. Not the best I know to photograph jewelry but cannot afford a different camera now. After I've taken the picture I open it in IPhoto. I make...
The following will help to get the best possible pictures from your Fujifilm FinePix JX250:
TO CHANGE FILE SIZE:
  1. Press MENU/OK to display the shooting menu.
  2. Press the Selector UP or DOWN to highlight the option IMAGE SIZE and press the selector RIGHT to change IMAGE SIZE to 14M. This setting has a image resolution of 4,288x3,216.
  3. Press MENU/OK to select the highlighted option.
  4. Press DISP/BACK to exit from the menu.
TO CHANGE QUALITY:
  2. Press the Selector UP or DOWN to highlight the option IMAGE QUALITY and press the selector RIGHT to change IMAGE QUALITY to FINE (Less compression than NORMAL, meaning better picture quality).
NOTE: The focus range of the JX250 goes from 1.5 ft. - Infinity (Wide Angle), 2.6 ft. - Infinity (Telephoto), also make sure to clean the lens and adjust the focus before taking the photos. If the subject is close to the camera, select Macro mode. If the subject is far away from the camera, cancel Macro mode.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 28, 2011 | Cameras
I dont know if i can transfer pictures from the internal memory to the memory card
Yes you can. Make sure there is a memory card installed. Set the camera's image storage to internal memory. Press the Review button, then press the Menu button. Use up/down to highlight Copy, then press the OK button. Use up/down to highlight an option, then press OK.
To change the camera's image storage location, press the Menu button. Use up/down to highlight Image Storage. Don't forget to change it back when you're done, or any further pictures will go to internal memory even with a card installed.
Feb 15, 2011 | Kodak EasyShare C633 Digital Camera
How to transfer images to the memory card
Insert a card and set the camera's image storage location to internal memory. Press the Review button, then the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
To change the camera's image storage location, press the Menu button. Press up/down to highlight Image Storage. Make sure you change it back to Auto if you want to use a memory card for subsequent pictures.
Dec 03, 2010 | Kodak EasyShare C653 Digital Camera
On the Kodak EasyShare C643, I need to copy the pictures in the INTERNAL memory to the SD Card.
Make sure a card is installed and that the camera's image storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy>>, then press the OK button. Press up/down to highlight an option, then press the OK button.
To change the camera's image storage location, press the Menu button. Press up/down to select to select Image Storage.
Aug 20, 2010 | Kodak EasyShare C643 Digital Camera
How to transfer pictures from internal memory to memory card
Make sure a card is installed and the camera's image storage location is set to internal memory. Press the Review button, then the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option. Press OK.
You can change the image storage location in the Setup menu.
May 24, 2010 | Kodak EasyShare C613 Digital Camera
How to overlay picture in D40x camera
Overlaying pictures, like almost all photo manipulations, is better done on a computer using "real" software rather than on a camera. You get much more control on a computer. However, the D40 does have a wide repertoire of photo manipulation capabilities.
In order to overlay images, you must be shooting in RAW (or RAW+JPEG). Select Image Overlay from the Retouch menu. A preview dialog will be displayed with Image 1 highlighted. Press OK to get a photo selection dialog. Use left/right to highlight the first picture in the overlay. (You can press and hold the Zoom button to see the selected photo fullscreen.) Press OK to select the image. Optimize exposure for the image by pressing up/down. Press left/right to highlight Image 2. Select the second image the same way. Press left/right to highlight the Preview column. Overlay will show you the result, allowing you to go back and change things if you wish. Save will save the overlaid photo.
The shadow in the lower portion of your camera is probably caused by the lens hood. The solution is simple: remove the lens hood whenever you're using the built-in flash.
Mar 05, 2010 | Nikon D40x Digital Camera
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must
also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To save a scan to a memory card
1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One.
2. Load your original print side down in the right front corner of the glass.
3. Press the Scan Menu button.
4. Press to highlight Scan to Memory Card, and then press OK.
The HP All-in-One scans the image and saves the file to the memory card in the JPEG format.
To scan a photo and reprint it
1. Press Reprints.
2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following:
To reprint your original photo using the default print settings
➔ Press Print Photos.
To change print settings before reprinting your original photo
a. Press OK.
Basics Guide 13
HP All-in-One overview
b. Press or to highlight a paper size, and then press OK.
The paper size choices available vary depending on your country/region.
Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages.
c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK.
The HP All-in-One scans your original and shows a preview of the photo on the display.
d. Press OK to display the selection menu.
Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies.
If you want to edit the photo before printing, press to highlight Edit
Photo, and then press OK.
e. Press to highlight Done, and then press OK.
The Print Summary screen appears.
f. Press or to highlight one of the following options, and then press OK.
Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and
time stamp on your photo.
By default, the Paper Type is set to Automatic and the
Date Stamp setting is set to Off. If you want, you can
change the defaults of these settings with the Set New
Defaults option.
Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and
wasting paper and ink on potential mistakes.
Print Now Prints your photo with the size and layout you selected.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Scan Menu.
3. Press to highlight Scan to Computer, and then press OK.
4. If the HP All-in-One is connected to one or more computers on a network, do the following:
a. Press OK to select Select Computer.
A list of the computers connected to the HP All-in-One appears on the display.
Note The Select Computer menu might list computers with a USB
connection in addition to those connected through the network.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Press the OK/MENU button and then press the right arrow button to enter the Mode Menu. Press the down arrow button until the SETUP tab is highlighted. Press the right arrow button and then the down arrow button until PIXEL MAPPING is highlighted. Press the right arrow key, which will highlight START. Press the OK/MENU. The back of the camera will display an indicator bar with the word BUSY. Once Pixel Mapping is completed the Mode Menu displays. Press the OK/MENU button to resume normal picture taking. The bright dot should no longer appear in your downloaded images.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
35 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
