Question about IBM ThinkPad R40 2722 Notebook
Number lock when booting and using password with letter o in it keyboard works fine,after booting in any application, word, notepad, etc the letter p comes up as * lettter o as 6 etc.have tried everything I can think of. same result. However when unit is connecter to docking station with external keyboard both keyboard work fine. Any ideas, all help is greatly appreciatedLarry
  • junkmail246 Oct 09, 2008
    I too have the same issue. BIOS is set to "Off" for the numlock. When I boot up XP it turns itself back on. I have to + to disable it. After rebotting it comes back enabled again. What gives?
  • 53 Answers
The laptop is switching numlock on, you need to disable this in the laptops BIOS
Posted on Nov 09, 2007
  • Robert sturzbecher Nov 09, 2007
    the laptop is switching numlock on during boot, you need to disable this in the laptops BIOS
My email n password dont match, how can I fix it?
The procedure to troubleshoot email account login issues may vary depending upon your email service provider. So, to let us suggest you a specific solution, can you please share with us the name of your email service provider?
In the meanwhile, we recommend you to make sure that all the keys on your keyboard are functioning properly. If one or more keys are jammed or have stuck up, the keys that you hit may not display characters correctly on your login page. Also, make sure that the functional keys like Caps Lock and Nums Lock are On or Off only when required. To make sure that the keys on your keyboard are working fine, you can first try typing your email ID and password on a Notepad or Word Document and see if they come up correctly. If the keyboard is working fine, we suggest you to try typing your email ID and password slowly (if you have not done this already). Also, give special attention to characters like 2 or Z, 0 (zero) or O, 1 or I, 5 or S, 8 or B etc.
If one or more keys on the keyboard have become malfunctional, try logging in to your account through some other device (if you have not done this already) or consider using a different keyboard (if possible).
You can also try onscreen keyboard by press and hold the Windows key and hit the letter R. Type in OSK and hit enter. Try using the onscreen keyboard if the keyboard is not functioning correctly.
GuruAid.com
Jul 17, 2014 | Computers & Internet
I password my laptop (samsung R510) and one of the key I used is not working and I got an external USB keyboard by the keyborad is not working with, what will I do to used the external keyboard
your USB keyboard may not work because your laptop has not got to the point of initiating USB at the point of booting to password.
You could try using ascii codes to eneter the key
at the point where you need to enter the key that doesnt work press your numlock button this will turn some of your letters into numbers...they should be written on the keys in a different colur...the laptop Im looking at at the moment has 4 on U, 5 on I 6 on O, 1 on J etc...
hopefully these are not the broken key..
if you look here you will see the chart that says A=65 B=66 etc in order
http://www.asciitable.com/
find the letter you need eg v=118 in lower case
type in your password till you get to the v (if thats the broken letter)
press and hold [ALT] button with num lock on and on your newley formed number pad type in the number thet represent the letter in this case 118 when you release the [ALT] key it will insert that letter.
however this only works with an extended keypad (like a full size keyboard) where the numbers are seperate not your top row numbers which is why you need your numlock on.
HTH
Richard www.2pages.co.uk
if it does then work maybe you could go into your bios and turn USB legacy support on...which may then help your full size keyboard to work too.
Jul 28, 2011 | Samsung R610-64G Laptop
I press certain letter keys and numbers appear, the number keys are fine just the letters, what is the fix for this error?
You have your numbers lock on, press the NumLk key and that should correct it. You will notice on you keyboard that there are small numbers on it below some of the letters, this is so you can use the keyboard has a 10 key number pad/ calculator etc. If pressing the NumLk key does not work, the key may be stuck or you have a bad keyboard
Oct 12, 2010 | Panasonic Toughbook CF-51 Notebook
My Dell XPS M1530 is experiencing a key lock problem (keys Y,U,H,J,N,M and 6&7)
You need to check if your keyboard is working fine or not. First of all if you have an external USB keyboard, try to use it. You can also try to use the onscreen keyboard. Go to start>programs> accessories> accessibility and choose on-screen keyboard. Open a notepad and check the keys which are not working. If you are able type those letters, it means that the integrated keyboard needs to be replaced.
Nov 01, 2009 | Dell XPS M1530 Laptop
How to unlock sandisk u3 micro 4.0g password problem
Try 0000
If not then bring up notepad and type you password into it to make sure that your keyboard is working OK ie no double letter etc. If you want to remove the protection you should search for and download a utility called U3Uninstall its on the SanDisk website- hope this helps
Aug 18, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Laptop compaq N2660 keyboard not working, does this have a keypad
try to boot up machine again. i suspect you keyboard just went hang.
Jul 01, 2009 | HP Compaq nc6220 Notebook
Password will not work
may b a key board failure. Go to safemood aln check also.
When the machine boots up press F8
then go there and check. If its not a virus, it will work fine
If not you need to clean the keyboard
Thanks
Please rate the answer if it helps u
Jun 24, 2009 | ASUS Eee PC 701SD
I dont know anything about cap locks i have to get a new password every time i log in to facebook and i dont know why they keep rejecting my password HELP
Caps lock is that key on the left side of your keyboard. When pressed, it makes all letters that are typed in into uppercase letters. For example; without caps lock pressed: "pressure". With caps lock pressed: "PRESSURE". If it mentions something about passwords being "case sensitive," this means that an uppercase letter A (A) is recognized differently than a lowercase letter A (a). Since you can't see your password being typed, it is important to make sure caps lock is not pressed. If this becomes too complicated, open up MS Word, notepad, or wordpad and type your password there so you can see it, then copy and paste the password into the password space on facebook. Good luck with that.
Nov 15, 2008 | Computers & Internet
How do you unlock a few locked keys on my laptop
Can you tell me whether this is a bios power on password, a hard drive lock password, or a windows administrative operating system password? I'm assuming that it is asking for a password when you say "locked".
Jun 26, 2008 | Computers & Internet
Number pad
There is a Fn key on the bottom left of the keyboard and a num lock key at the top right of the keyboard (depending on the model) Hold the Fn key and then press the num lock key, that should fix your problem.
Dec 10, 2007 | Zippy EL-610 Electron Luminescent Keyboard
IBM ThinkPad R40 2722 Notebook Logo
250 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
