Question about HTC Touch Viva Cell Phone
When i plugin my handsfree to my htc viva it goes on voice commander and reconnects last dialled calls
    Brigadier General:
  • 3,006 Answers
Yes, many HTC models tend to do this. As you insert the plug a signal is generated which makes the phone think that you've pressed and briefly held the handsfree's dial button and so it takes it as a command to redial last number..
All you can do is to turn the phone off before plugging in the handsfree, or get ready to hit the call disconnect button each time you connect it with the power turned on.
Best fix is to abandon the wired version completely and use a BlueTooth handsfree instead.
In some countries (such as here in the UK) a wired handsfree falls foul of the laws regarding driving whilst using a handheld phone and the handsfree solution must be one which allows the driver to be completely physically separated from the phone and which holds the handset securely and safely away, i.e. you can't have the phone lying unrestrained, nor can it be in the driver's pocket.
Posted on Jul 02, 2009
Hi, am using htc touch, wenevr i connect my headphones,which ever is the last call ,.it gets automically dialled.this is because of voice commander... PLS let me know how to disable this voice...
Hi, you can remove the voice command by using the manual for instruction. You can download the manual from the below link:
member.america.htc.com/download/web_materials/Manual/HTC_Touch_Viva/Opal_HTC_English_UM_1013.pdf.
hope it helped.
Oct 13, 2010 | HTC Touch Viva Cell Phone
Xperia x10 how to install voice commands for contacts
Hi
Voice dialling is already pre-installed on the Xperia X10.
Its in the main menu.
just tap the bottom of the screen and drag upwards.
Near the bottom of the icon list is "Voice Dialling"
Tap it and say "Call" then whom-ever you wish to call.
I will warn you though...
Out of 10 tries to get it to work on my phone only ONCE did it manage to select the correct app or contact.
I gave up and used phone book instead. It's quicker.
Thanks
Aug 13, 2010 | Ericsson Cell Phones
When i call anyone from my HTC VIVA, my voice at other end is very low. Any Solutions?
1. try calling to some other mobile phone and test your voice at the other end. If still voice is low in all the receiver's mobile, then we need to check your mobile.
2. Connect the headset with mic to your mobile phone and speak via it. If hears well, then there might be problem with your mobile's in-built mic and you might need to check it in HTC service center.
3. Try using a bluetooth headset to make a call from your mobile and speak via it to check again.
I hope this helps
Thanks
Jul 29, 2010 | HTC Touch Viva Cell Phone
I cannot connect my HTC legend to Mercedes Benz car kit
When you state that they will "pair but not connect" does this refer to incoming calls, outgoing ones, or both?
Unfortunately ALL current HTC's have a very crippled Bluetooth chipset fitted and this may be the cause of your problem. For example, none of them (Windows Mobile included) are capable of handsfree Bluetooth voice dialling and this is particularly bad given that WinMo is very strongly featured with voice commands and many HTC models from about three/four years ago had these features as standard. The crippled chipset also means that until very recently, most HTC models could not use Bluetooth to transfer files of any kind, but some models such as the Hero have recently had an update to allow limited functionality in this respect.
I can't state with certainty that the problem you have is to do with the poor Bluetooth chipset which HTC currently appear to be contractually obliged to use, but it's a definite possibility. What is definite is that it's not an Android issue (although Android current and planned releases do not yet incorporate Bluetooth voice dialling either, but that's not an issue when you're using the car to handle the calls).
If you can add details of the exact make and model of your vehicle then I'll try to look into this further for you: it's also not uncommon for vehicle manufacturers to install poorly chosen Bluetooth chipsets and sometimes the cause is a simple case of Brand A simply being unable to get along with Brand B. If you're in a real hurry to resolve this, then definitely change your handset, but insist on being able to try the replacement out with your car before committing to it.
Across the board, Bluetooth on many phones seems to have regressed and is poorer than it was a few years ago. Even the i-Phone is very poor except for the flagship 3GS but even that model is *very* picky about which brands it will usefully work with. Currently, the best and most reliable Bluetooth in my opinion and experience is in the Blackberry range of handsets. If you don't want one covered in buttons then go for the Storm 2 touchscreen. It's not as fun a gadgety as the HTC and Apple models, but is a good solid performer and does everything a phone/mobile browser needs to do very competently.
Apr 30, 2010 | HTC Touch HD Smartphone
No voice during normal call
it looks that you have a hardware problem you can fix that by replacing the earphone speaker ( or if you don`t want to just use a handsfree kit)
Mar 15, 2010 | HTC Touch Diamond Smartphone
I want to make and receive handsfree calls using an LG HBM-730 bluetooth device and an LG CF360 phone. I have the bluetooth and the phone connected and can receive calls and make calls. The kicker is...
Hello.
From LG Documentation:
To make a handsfree call from the bluetooth device (Voice dialing)
- Briefly press the PWR/END button to activate “Voice Command”.
You will get the best results if you first record the voice dialing tag through
your Headset.
Hope this helps
Mar 09, 2010 | Cell Phones
Voice dialing does not work at all. I press the
Your question gives insufficient information regarding which call button you're referring to, and no information about which country you're in so I'll have to stab around a bit and hope to hit the spot..
If you're asking why doesn't Bluetooth voice dialling work, then the answer is simple and really annoying: The Hero does not support it. Some folks claim it's just because it's not yet been added to the Android operating system, but I was told by HTC and T-Mobile tech experts that the phone does not support it at the basic hardware level. I don't trust the latter argument as there's now a few folks who claim to have transferred the application into the Hero by copying the files from a different HTC model (scroll down to post #44 onwards). I haven't been able to test this as I sent my Hero back when I discovered the lack of Bluetooth voice dialling. Android 2.0 *might* have it according to some, but the Android 2.0 website does not list it as a feature. HTC have not yet released their version of Android 2.0 yet so it's a case of wait 'n see.If you're with T-Mobile then the delay will be even longer as they'll need to tweak HTC's version of Google's Android 2.0 into a T-Mobile G2 variant <rolls eyes>. My understanding is that it will still be absent though.
If you're in North America, then the Hero already has voice dialling...sort of. Holding down the call key for a couple of seconds on the phone activates it. But you'll first need to touch the phone to wake it up, activate the voice dialling and then manually transfer the call to your headset. Utterly useless, and totally illegal in the many places where it's illegal to touch the phone whilst driving. On some networks the feature seems to be disabled and it does not work at all on UK/European models of the Hero.
There is another way to get voice dialling, but I'm unclear as to whether it will work via a Bluetooth headset: basically you install Google Voice onto your phone which allows you to search your contacts by voice command. Currently it's available only to those who reside in the USA.
Hopefully I've answered your question in which case I'd ask that you return the favour by rating my answer. If not, then please add additional relevant details and I'll try to improve upon my answer for you.
Jan 06, 2010 | HTC Hero Smartphone
Bluetooth Handsfree headset not clear.
You can tweak the bluetooth to give best results from the bluetooth option. But by doing this your battery charge will fireup very fast... :-)
Jul 11, 2009 | HTC Touch Viva Cell Phone
HTC Touch Viva Cell Phone Logo
164 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
