Question about Refrigerators
My side by side smeg sra2one keeps ticking for 30 seconds every haldf an hour or so, when i dispense water it ticks, however if i dispense water with the fridge door open it is quiet - what is the problem?
  • 4 more comments
  • paul_davi395 Jul 02, 2009
    Hi Mannu, the clicking is coming from the bottom rear left of the unit, strangely when you push the water dispenser with the doors closed, the clicking comes again and the water is pumped in spurts at the same rate as the clicking - does that help?
    it is not leaking, it sounds like it is trying to pump water?? maybe into the ice maker?? it has been doing this for six months and now it is loud and unbearable, the unit is only two years old
    Hi Mannu, the great news is I am not silly, if it were under warranty I would not be using this site - do you have experience working on Smeg fridge/freezers? I had an engineer call out and paid $100 for him to tell me it may be the relay powerboard and that would cost $300 i asked may be the relay motherboard? or is the relay motherboard he said he wasn't sure -is there anyone there who is an expert on these? Paul
    Can anyone else help?
    I will definitely defrost it and see what happens, do you mind if i don't close this off yet? thanks
  • paul_davi395 Jul 16, 2009
    Guys I have emptied the fridge freezer and defrosted it for 24 hours and still nothing - has anyone come across this problem before? Please help
  • 749 Answers
You need to unplug it and defrost it, keep it dry and in approx ~5 hours try it again. this should solver your problem.
Posted on Jul 02, 2009
    Genius:
  • 1,847 Answers
The only fix for this is to completely defrost the fridge. (As in, unplug it for at least 24 hours) The reason is because there is no way to access the tube in the door... it's "foamed" in place and not serviceable.
Thanks
K
  • 296 Answers
From my expierance the problem is either mechanical or electrical in nature. First check all over the freezer and see if you have any frost. then push on the waiis and floor and see if you hear and crunching of frost or ice. If either of these tests show positive for frost or ice you probably have a defrost problem. The first thing to check is for a wire diagram or possibly for a code key that will tell you if your defrost heater circut is open or closed, and if you have frost you want it closed, If tyhe heater circut is closed then the only item left I can think of is the defrost iniator, or timmer depending on if its solid state or electromechanical. If the computer in a solid state lost memory on how often to defrost you may have to reprogram it or if this option isnt available replace the iniator assy.
Now if you dont have any frost - any where - you have covered most of the areas that can be, namely cleaning the unit. Now to the 1 clue that gives me the most insight is your "clicking every 30 seconds". This sounds very much like a defective relay/overload/(possibly) capicator as say on the compressor or the compressor itsself. If you find the parts list look for all of these items and purchase them and replace them on the compressor. If it does the same thing - sorry its no go and your compressor is bad most likely. If I m wrong and the compressor is runnig and the click is something else then you could have developed a leak and lost all refrigerant.
Thanks!
  • Rakesh Kumar Jul 02, 2009
    well in that case there is some problem of leakage and u need to get it repaired soon else it may become a bigger problem
    okie well in that case the refrigerator is under warranty why not get it repaired dude by the service center.The problem could be in the pump and may be the leakge too
What is causing a loud ticking sound instead of a normal boat engine sound when accelerating in my boat?
One of the spark leads has come off or has chafed against something wearing away the insulation, thus the ticking sound, spark going elsewhere instead of the spark plug. Make sure the plug leads are secure and in good condition, make sure no water has entered the engine cyl head area
Aug 13, 2015 | Cars & Trucks
How to remove tick?
First of all put a little vinegar in the dogs water that keeps the ticks away next ticks look like a small crabs the size of a dot and becomes the size of a pencils eraser.. it sucks the blood of the dog and get that big. When you see a tick that big you have to pinch the dogs skin below the ticks teeth and pull it off and mash it or it can get on you. It loves blood. If you pull just the body the teeth will keep sucking and what a bloody mess I\'ve done alot of pinchen. Good luck
Jun 04, 2014 | Home
Dont know hoe to set the coreect time and date
Thank you for contacting FixYa.
ANALOG
  • Locate the knob on the side.
  • Pull the knob out. The second hand should stop ticking.
  • Twist the knob clockwise until the correct time is displayed on the watch face.
  • Push the knob back in, and the the second hand will resume ticking.
  • Digital Watch
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right sidePress the "Date Advance" button on the upper right side. This will reset the seconds.
  • Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
  • Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
  • Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your setting.
  • Best regards. Jewel
    Sep 13, 2010 | Watches
    Second hand stops, then ticks four ticks very fast then stops,
    It may be that the battery is getting near the end of its life.
    May 05, 2010 | Tag Heuer WAH1112.BT0714 Formula 1 watch
    Ge model 20, 22, 25 side by side refrigerator. A loud clicking sound from the back of the refrigerator. It sounds like a clock ticking on the second. No water is being dispensed and when I push on the...
    there is a mother board in the back that go bad the clicking to hear is the micro switch on the board try to cick in but when they go down you need to replace the whole board :(
    Jan 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
    My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
    Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
    May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
    I have a GE SxS that I bought in Sept. 06. About
    First you need to turn the freezer temp control back on(That just turned the whole refrigerator off)
    The water dispenser may have stopped due to line freezing inside the refrigerator.
    The ticking could have been the the element for the defrost cycle or the starter on the compressor.
    So,turn it back on,set the temp to a normal setting and if the ticking is still there,wait 30 minutes to see if it stops,If no ticking is there when you restart it,wait 24 hour and check the temp inside as well as the water and ice dispenser,If all work,It is a defrost issue.If so you will either need a defrost timer,defrost element,or defrost thermostat.
    If the ticking is still there,You will need to replace the start/run capacitor.
    Apr 16, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
    Refrigerators Logo
    79 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
