Question about Yamaha RX-V650 Receiver
Yamaha RX-V650 receiver won't power on
I have exactly the same problem did the solution offered fix it?
  • 4 Answers
SOURCE: Yamaha RX-V596 Receive turns off after pressing Power
Sometimes the receivers turn off if the speakers are shorted in order to protect the AMP circuit. So try this - 1. Disconnect all cables (speakers), inputs from Tape Deck, VCR and other input devices), sub-woofers, rear speakers all. Except the AC power cord. Then turn it ON and see if it stays on. If it still has the same problem, then most probably your power circuit inside the receiver has a problem - like a shorted Capacitor or diode etc. Based on how technical you can be and what resources and time you want to spend, this is repairable. But based on the price of a receivers these days, it is not worth. Good Luck!
Posted on Sep 01, 2007
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
SOURCE: Yamaha Rx-V870
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
ButtFuzz
  • 463 Answers
SOURCE: Yamaha RX-V650 receiver won't power on.
You've probably already tried this, but...
Disconnect power from the mains, remove lid.
Reseat all the low-power connectors in the unit.
Check the thermister on/near the main transformer.
Check capacitors on or near power supply for obvious anomalies (fattness, leaking, smoked, etc.)
Replace lid and, plug back in, do a rain dance and hope.
Posted on Mar 04, 2009
SOURCE: yamaha av receiver rx-359
go to best buy and buy a new recever
Posted on Apr 10, 2009
How do I reset Yamaha rx-a4730 it won't turn on just blinks Manual says it is in circuitry protection mode
Yamaha RX-V650 won't power on - Service manual, repair and unlock ...
forum.eserviceinfo.com/viewtopic.php?t=59945
10 posts - ‎6 authors Posted: Sat Aug 29, 2009 1:26 pm Post subject: Yamaha RX-V650 won't power on ... When i came back from a holliday, my receiver won't power up anymore. .... isn't powered (no voltage on the base) when the receiver doesn't comes on.
Sep 12, 2015 | Yamaha Audio Players & Recorders
Power failure with yamaha RXV1600 areceiver
Google yamaha rx-v1700 power problem and you will find that a
capacitor # C4 is failing throughout the RX-V line of receivers. It's
an easy replacement fix but on some earlier models it may be
labelled C6 - the fix post has pics of it and specs - readily available.
Capacitor is a 0.022UF 630v.
Apr 07, 2014 | Yamaha RX-V1600 Receiver
Cannot Power Up, Sometimes can
i had a real nice yamaha natural sound receiver and the relay that switched it on went bad a lot..... try the relay???
Apr 26, 2010 | Yamaha RX-V650 Receiver
Intermittent output from speaker channels
i would swap speakers from side to side and check if it is the speaker of the amp. good luck
Feb 10, 2010 | Yamaha RX-V650 Receiver
My Yamaha RX V365 will not turn on anymore. It
Most likely, one of the channels is blown, or you having power supply issue. It is hard to determine exact cause of the problem with out looking at the unit.
Nov 28, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha rx-v650 wont come out of standby, fuses ok switchmode ok no display at all fault pointing towards microprocessor problem.
There is a common psu problem occurring on a few Yamaha models from ~4 yrs ago. Any Yamaha dealer should know what it needs. probably the mod component in the stby supply.
Doubt it would be a micro fault.
Oct 28, 2009 | Yamaha RX-V650 Receiver
Mar 04, 2009 | Yamaha RX-V650 Receiver
HARMONY 550 UNIVERSAL REMOTE
As far as I know you cannot, you will need it to be in the devices list online, or find somebody with the remote to program it.
You should also be able to get the company.. Yamaha to send you the codes or send them directly to Logitech to get them added to the database.
Aug 25, 2008 | Logitech Harmony 550 Remote Control
Yamaha RX-V650 Receiver Logo
326 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
