Stripped the washing machine
Hi there,i just stripped this washing machine quickly but i need assistance with regards to a manual or sketch of the washing machine please.
    President:
  • 942 Answers
Hi..
just click the link below that i can provide
http://www.repairclinic.com/0088_11_1.asp
Goodluck
Regards
PCmania
Posted on Jul 02, 2009
    President:
  • 2,976 Answers
If you stripped, it's apart. the manual will just show some assemblies. Go to the whirlpool website or one of the many appliance sites. You will need the model and possibly the serial number if you are trying to put it back together.
Machine is very, very loud during the agitation cycle..
Good web site to go is: www.repairclinic.com
They have great videos that may assist you in fixing your problem
Jan 01, 2017 | Washing Machines
I stripped the head of the shaft end bolt of my Frigidaire front load washer. How can i get the bolt out ?
There is a special socket set made for stripped nuts and bolts. Sears sells it. There are about five sockets in the kit, each covers a couple different sized stripped nuts/bolts. The socket is spiraled inside and tightens onto the stripped head as you turn it counterclockwise to remove..... DW
May 12, 2014 | Washing Machines
Front load washer will not spin
Good Afternoon Kevin,
I see that you are having trouble with your Frigidaire washer not spinning and making a grinding sound as if something were stripped. I also see that changing out the door lock and switch assembly, did not help the issue.
I would suggest contacting either the manufacturer or your local authorized technician for further assistance. They will be able to diagnose what is causing the grinding sound and better assist in resolving the grinding sound. Hope this helps.
-Best Regards-
WP
Apr 21, 2014 | Frigidaire FRT18HS6JS Stainless Steel Top...
SPLINES STRIPPED
Replace this agitator coupling part number WH49X10042 make sure the inside of the agitator is not stripped.
Feb 05, 2014 | GE Profile WPSR3100W
FILLS UP, DOES NOT SPIN, BUT TRIES WITH CLICKING
master gearbox is stripped a cog it will need to be repaired in most gear box cases the cost outways the replacment of a new washer
sorry
take care
Feb 15, 2011 | Washing Machines
Hitachi SF-65PX Washing Machine
Hi just read your posting.As I understand from your posting, the center spline on your pulsator is stripped and you would like to replace only the center spline instead of the whole pulsator.Is this correct?Are you in Australia?If so then reply back and I can give you some contact details on where to obtain a pulsator from.I dont think you can buy just the center piece only the whole pusator.There are places that sell the pulsators secondhand which will save you some money.Please reply with additional information and I am sure I can help you further.Looking forward to your reply.
Jul 24, 2010 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Hi, The water comes into the load, but then their
the agitator shaft could be stripped out. does it sound like the motor is working during the wash cycle or is it just idle? This is a common problem with ge washers the agitator strips out on the transmision and needs to be replaced.
Jan 02, 2010 | GE WJSR2070B Top Load Washer
Washing machine is making a clicking/ticking sound when it is agitating during wash cycle
This is a sign of strained agitator components that are about to be damaged or stripped. I recommend pulling the agitator and clutch. inspect each device for stripped components and uneven ware. replace the agitator and clutch if found to be faulty.
Check the transmission(gear box) for damage as well. fill with oil if needed.
May 27, 2009 | Washing Machines
WHIRLPOOL LSQ8511KQ0
helzie, sounds like your drive block stripped out. You would get this from the top. You would need to remove the tub ring, agitator, lock nut and pull the basket from the tub. I will attach some pictures so you can visually inspect it. The part is cheap, part number 389140, but you can expect to pay around 140.00 labor. Check out the pics, you will see that the spin tube has 2 ears that sit in the drive block slots. See if your is stripped out. 99ddcb9.jpg
Nov 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
