Question about Datalogic Magellan 1000i Hands Free Barcode Scanner
I have Datalogic Magellan 1000i image scaner,the
I have Datalogic Magellan 1000i image scanner,the problem is follow when I connect the scanner true the USB port PC is need very long time to recognized (about 3 to 5 min ) and after that i receive info your device is installed but not work properly. After that, scanning of any code is accepted but is not visible (in word or excel).
Please can you give me any solution about these problem
2 Suggested Answers
rdiodoro
  • 13 Answers
SOURCE: problem with datalogic magellan 1000i barcode reader
hi
the cable is USB?
if you have usb cable, you read the manual paper "default".
if you have cable rs232 you must install on a PC emulator "softwedge". Open icons and set a comm. Prefer you answer. bye Roberto
Posted on Dec 17, 2008
Magellan 1000i driver
Does this mean you want to turn it off?
Jul 20, 2014 | Datalogic Magellan 1000i (MG100010101106)...
Usb port open error
Does it work on other POS machine? That is to verify any hardware issue with the scanner. If it works, does other scanner works on this POS machine? Sometimes unplug and replug some USB cable in or some of the cable in between the POS and scanner will make it work. If those do not work, try to check the server for POS connection and see whether they can see that POS system. Use your store control application to reset that POS machine before you refresh the software or operating system on that.
Sep 11, 2012 | Datalogic Magellan 1100i Barcode Scanner...
Sir lost my barcode my name is sujajoseph kochithara house p o naduvil kannur
You can try slowing down the output of the scanner. Most barcode scanners have a setting called "inter-character delay". This setting puts a very small amount of time in between the transmission of characters from the scanner to the host PC. See if you can find setting like that in the users guide for the scanner. I did a quick search for the users guide to see what they might call this setting but was unable to find the users guide. I'm pretty sure this scanner has been retired for quite a while now. Probably since PSC was purchased by Datalogic. You may have purchased it new, but most likely it's been sitting around for awhile. If you do find that setting and it doesn't help, see if the scanner supports a USB connection. If it does you'd need to buy a USB cable for the scanner and replace the PS2 cable you have with the USB cable.It could be the adaptor you purchased is causing the problem. If all else fails call Datalogic support. Their website is listed below. Source(s): http://www.scanning.datalogic.com/
http://www.barcodehelponline.com
May 17, 2011 | PSC Magellan SL
How can read 2d barcode?
go to: www.scanning.datalogic.com/sitefiles/mg1000i.aspx
or
www.barcodesinc.com/cats/barcode-scanners/hands-free.htm
Feb 24, 2011 | Datalogic Magellan 1000i Hands Free...
Vertical laser error
If the error code means "vertical laser error" you could check for the flat connector of the vertical laser module. Here I send to you an image to explain it. 0b500ff.jpgIF all is ok. you could try with another vertical laser board and replace it
Apr 20, 2010 | Datalogic Magellan 8500 Wired Barcode...
Configuring (changing) barcode reader suffix
Reset tbe scanner and again program the scanner for your required configuration.
Aug 15, 2008 | Datalogic Computers & Internet
Problem with datalogic magellan 1000i barcode reader
hi
the cable is USB?
May 16, 2008 | Datalogic Magellan 1000i Hands Free...
The red light on the scanner seems to be on most of the time
If you are using magellan 1000i with no button, then it must be your scanner broken. But If you use a button trigger try to push it a while. The Button is on top of the scanner,with a white / light green color.
Aug 10, 2007 | PSC Magellan 1000i Barcode Scanner - P/N...
Ds 2100 escaner
Hi, You can check following: -The DS2100 Scanner better works with a voltage close to 30V (24V for example). When the voltage is to low (near 10V) it can appends that the motor stops. -If the Scanner is an DS2100A, is it possible to start/stop motor with a serial string. - It can also be a mechanical problem. Regards,
Apr 25, 2007 | Datalogic DS2100 (ds2100-1100) Fixed Mount
Datalogic Magellan 1000i Hands Free Barcode Scanner Logo
99 people viewed this question
Top Datalogic Computers & Internet Experts
Paul Bade
jackcity
jackcity
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
