I have a Fisher & Paykel GW512. The lid wont lock to allow it to spin so constantly beeps at spin cycle. My husband has put a multimetre on the solenoid and it is producing 5 to 7 vaults. He has bench tested the solenoid and it works fine and the pump is working ok. Now when I try to reset it it constantly beeps power and spin light together. Any ideas? Thanks
  • joyjefford Jul 02, 2009
    HI
    I have completed diagnostic test and the following buttons illuminate:
    Long wash button and the one inbetween the rinse and spin button.
    What would that be?
    Cheers
  • joyjefford Jul 04, 2009
    Many thanks it helped us diagnose problem - we need the new electrical board.
  • 2,071 Answers
This symptom is in control panel circuit.The common causes circuit problem is cold solder or loose connection that why the machine function abnormally .Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the unit turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough. Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components.You just resolder all component joint parts in the control panel circuit board. Also its better you replaced that lid switch maybe its faulty.
Good luck:
Regards:
VOTIT
Posted on Jul 03, 2009
    President:
  • 987 Answers
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode. Press the spin speed up button until the hold and slow are lit. Write down the LEDS which are lit across the top row of progress LEDS.
Posted on Jul 02, 2009
  • serendepidy
    serendepidy Jul 19, 2012
    Not sure if you will get this but I have the same problem, the leds that are lit for me are as follows, orange lit, yellow lit, yellow lit, not lit, yellow lit, not lit, orange lit, not lit. Any help would be very greatly appreciated
    Sergeant:
  • 326 Answers
Http://www.fisherpaykel.co.nz/admin/pdfs/pdf_usecares/420983_Smartdrive_UC_UD1.pdf
Mw512 beeps and wont start
The lid switch sounds logical. That would certainly halt the cycle. I'm not sure what actuates the lid switch on your particular model but check it as well. Good luck.
Jan 13, 2013 | Fisher and Paykel Washing Machines
Fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Nov 05, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel washer wont start it beeps and says the lid isnt closed, but it is and there is a little ambulance that comes on the screen
I believe the lid switch is faulty, for the later modules the microswitch is mounted inside the door lock mechanism, others under the lid/top left side.
The ambulance is just saying to call for help....
May 17, 2011 | Fisher and Paykel Fisher & Paykel Washer
When i put the wash cycle on it goes and does fill up with water, but then when comes to spin cycle it stops agitating and starts beeping constantly with the light on where the "lid locked" icon is.. When...
Hi Ellie,Just read your posting.Now does your machine drain most of the water from the machine but it does not spin the clothes dry?Is this correct?Also does the mahine only show the lid lock icon when the machine is beeping?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Have Fisher & Paykel washer GW11. 5 yrs old. Lid won't lock, Took off to repair, then put back on, no problem, but now won't lock, so won't spin. Help!
your door needs to be re-aligned so the wax motor assy can lock the door so the unit senses its locked and can continue the wash cycles
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P GW512 compact wont spin
Hi just read your posting.Does your machine drain the water out?Starting from left to right what lights were lit on the progress bar when it started to beep?Was it the 2nd and 5th or 3rd and 7th---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel machine locked but lid is up
It sounds like the lid lock is either stuck or broken,You will need to lift the top hob by removing the two plastic lugs where the lid rests & removeing the screws it will then lift up and you will be able to remove the lock to inspect it,Also you can remove the lid in the up position by pulling vertically to make it a bit easier,Hope this helps Cheers.
May 21, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel GW612 beeps before spin.
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Mar 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
