Question about HP Compaq Presario V6000T Notebook
My v6000 gets a white screen after post !
I can tell windows is loading in the back round.
Turned of my laptop yesterday. now it wont turn back on, all I get is a black screen and the white arrow can anyone tell me how to get it to work again
Your laptop HAS turned back on.
One thing that is a problem is that the operating system hasn't finished loading.
You may need to use the recovery routine, or the hard disk could be dying.
Jan 30, 2015 | Acer Aspire Computers & Internet
I cant reformat my toshiba harman kardon?what seems to be the problem?
Try loading it into safe mode, to do this turn off your computer turn it back on and as it starts up hit F8 over and over until you get a black screen with white text that you can scroll through. Then look for something that says "Start windows in safe mode" and select that with the arrow keys to move and the enter button to select. If windows does not enter in safe mode, you may want to post clearer information as to what happens when it loads/doesn't load.
Aug 30, 2012 | Harmon Kardon Toshiba Satellite...
How do i get my guitar to sync with my xbox?
Hi, look for the sync button on the guitar, once you have found this all you need to do is switch your xbox on and wait for it to come on now when its on and the game is loaded or you can do this before you load the game, now you see the little round white button on the console its below and to the right of the dvd tray, well this button is the sync button so press this then the green lights should spin round the power button telling you its searching for wireless devices now when this is spinning round you can either press the sync button on guitar or if it dont have a sync button just press a few of the buttons then the spinning green light should stop telling you it has synced it and you should then be able to use it with no problems.
let me know if you have any further problems ok
please rate this solution and leave testimonial as i have pages of unrated posts as askers forget to leave a response or rate then answer, thanks
Dec 11, 2010 | Microsoft Xbox 360 Console
My Acer Extensa 5230 wil not load windows.. can get the DOS screen but just get a black screen with a white cursor when it tries to load windows. it is running windows vista
go into bios by hittin F10 when it starts up go to diag and run a test on hard drive to see if its bad. tell me if it passes bc if its good there are a couple of other things it could be.
Jan 27, 2010 | Acer Extensa EX4420-5239 Notebook
Compaq Presario V6000 screen goes blank after Windows Welcome
1st it could be virus or it could be monitors bad how to find need to hook it to out side monitor and test then get back to me lala linda
Jun 15, 2009 | Compaq Presario Notebook
Compaq Presario V6000, keeps rebooting, blank screen, and no post beeps. Replaced ram, battery, and power adapter. There is no hard drive light. I think it is a hardware problem, because it will not boot...
If your pc reboots just after post my first place to look is to reseat the hard drive and see if that makes a difference. If it doesnt you could try and repairing your windows operating system or doing a system restore. If the os loads sucessfully then i would say you had a corrupt boot file maybe from a virus or a failing hard drive. I hope this helps
Mar 24, 2009 | IBM ThinkPad T40 2373 Notebook
I cant get windows to connect on in seens stuck?
master boot record is damaged you need to format the drive
Mar 12, 2009 | HP Pavilion a1440n PC Desktop
My compaq Presario V6000 will not start windows, it continously loops to an options screen with the following start options; Safe mode, safe made with networking, Safe mode prompt command,Windows last...
what you are describing is the blue screen of death, meaning theres a hardware or software problem, try to boot into safe mode and perform a system restore, if that doesn't work use your XP cd, let it load the drivers and the ask it to fix the existing XP installation, anything that you have saved in my documents should be safe and the problem should be solved. If the blue screen reappears then you have a hardware problem
Nov 13, 2008 | Compaq Computers & Internet
Need audio driver of compaq presario V6000
usually all drivers for Compaq and HP computer systems (portable and non-portable) can be found on the HP support website (Click here to go to it), simply go there, chose your region, than your country, enter your model number (not the series, the model number, you would usually find it on the service tag, or wherever you would find a serial number), but be sure to chose "Download drivers and software (and firmware)", and than chose your operating system. Hope this has helped.
Jul 06, 2008 | MSI KM2M Combo-L (MS-6738-010) Motherboard
HP Compaq Presario V6000T Notebook Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
