Question about Gigabyte GeForce® 8500GT, PCI Express Graphic Card
My computer when i boot a message appered scanning bios image in hard drive..... bios auto-recovering and the computer restart... how to repair this error??
  • 60 Answers
The bios is stored in the CMOS chip on motherboard not on the hard driver, the error message probably means it it scanning to find a hard drive to boot to. You should go into your BIOS and reset to factory defaults and see if this makes a diffrence. you may also have a failed hard drive which may need to be replaced.
Posted on Jul 02, 2009
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
How to restore corrupted BIOS of presario cq60 laptop
Whenever you upgrade the BIOS on your notebook, a copy of the previous version is stored in the HP TOOLS partition of your hard disk drive. Many HP notebook computers have an emergency BIOS recovery feature that allows you to recover and install the last known good version of the BIOS from the hard drive, as long as the hard drive remains functional. This emergency recovery feature is separate from the BIOS and is designed to work in the event of a catastrophic BIOS failure.To recover an earlier version of the BIOS on your notebook:
  1. Turn off the computer.
  2. Plug the notebook into power using the power adapter.
  3. Press and hold the Windows key and the B key down at the same time while the computer is off.
  4. Still pressing those keys, press and hold down the Power button on the notebook for 3 seconds and then release the Power button and the keys. The screen remains blank for about 40 seconds before anything appears on the display. You might also hear beeping sounds. Eventually, an HP BIOS Update screen displays.note.pngNOTE:If the computer fails to display an HP BIOS Update screen, press and hold the Power button for 5 seconds to turn off the computer. Wait 5 seconds and try again. If, after repeated attempts, you cannot open the HP BIOS Update screen, your computer does not support this function or it has a hardware problem that is preventing the tool from opening.Figure 1: HP BIOS Update screenc03376208.jpg
  5. When the BIOS has been recovered, a Continue Startup button displays and timer counts down. You can click Continue Startup to restart the computer or you can allow the timer to reach zero and the computer will restart automatically.Figure 2: HP BIOS Update screenc03376209.jpg
  6. After restoring the BIOS, if the computer repeatedly displays a message that the BIOS has been reset, then perform the steps in HP BIOS Application Selected is Corrupt or Missing .
  7. After restarting, Windows may display a message stating that the computer was improperly shut down or that a boot problem was detected. Read and respond to the screens to continue.
Sep 22, 2012 | Maxtor Personal Storage 3200 (U01E200) 200...
My Asus F9e doesnt start anymore. Not even in Secure Mode. What should i do ?
Did you get any error messages? Since the BIOS is available, the problem is likely with the hard drive or it's trying to boot from non-bootable media (DVD, flash drive, USB connected floppy/hard drive). Since you can access the BIOS, look for the Boot Selection Order and make sure that the hard drive is first in the list. If the BIOS doesn't see the hard drive, it may be bad or have a bad power or data connection. (You can try opening the computer and reseating the cables - see Asus for any assistance. I am not informed on opening the F9e.)
If the hard drive is seen by the BIOS:
Disconnect any USB devices (and the optical disc if it is in the drive). Turn off the computer. Unplug the notebook from the power supply and remove the battery. Wait 10+ seconds (or a few minutes) then reconnect the battery and then the power brick. Try restarting the computer. (This is a hard reset.)
What do you see on the computer screen? If you see a blinking cursor, the computer doesn't have the boot manager available (either corrupted or a new disc that hasn't had the OS installed). Use a Windows install/upgrade disc/system repair disc for your OS version (the service pack must match) or a third-party disc management tool to attempt to repair the boot manager.
You will need the optical drive as the first boot device in the BIOS or press Esc to access boot order list. (On some computers, it's F12.) For Vista or Win7, boot from the CD and follow the on-screen directions until you see a list of choices. If the hard drive was previously working, click on Repair your computer. Select the OS to repair then click Next. Select the Command Prompt option. Type in bootrec /ScanOs to get a list of available Windows OS versions on the hard drive. Use the command bootrec /FixBoot to fix the master boot record. The command bootrec /RebuildBcd will rebuild the list of Windows OS versions. See http://support.microsoft.com/kb/927392 for details.
Installing a new hard drive and reinstalling the OS may be needed if you have a SMART or AHCI/SATA hard drive error. If you have a back up image, you may be able to restore that image.
I hope this helps. Please add a comment with any error messages for more assistance.
Jul 19, 2012 | ASUS Computers & Internet
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    Oct 09, 2011 | HP Mini 1000 Netbook
    Machine will not boot.. Black screen, message: "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key". How do I get it to see the hard drive, so I...
    In this case you need to repair your OS. You need to insert the OS which is a bootable disk, in case of net book you need to connect a USB with OS loaded in it and select boot from USB in bios, for entering in bios you need to press the F 2 button while restarting the computer.
    Jun 10, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
    I have been using HTS545032B9A300 320GB drive in my Samsung R428 laptop. One day, suddenly, its shuts down and never boots up. It never gets beyond setup. It hangs and showing "Entering into...
    When start your laptop,is their any spinning sound in your hard disk(Hitachi)?
    If so, try to go setup the bios ,just watch the laptop either detect or not,
    If your laptop detect the hard disk ,again install to the laptop, and remove the new seagate just for recover the data through following step.
    Please download hiren boot bootable ISO file ,
    Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
    Mazor problem is most of the user, burn ISO file in data mode and the result, it could not run in boot time.
    Burn the iso file, under image burning option from any nero .
    Boot from cd, no need to setup bios.
    DONT PANIC follow all the steep It is very simple. (Use the down arrow key.)
    1.INSERT CD TO CD TRAY
    2.Boot from cd
    3.Select start boot cd
    FOR REPAIR THE HDD DONT PANICI
    Choice hard disk tools
    1.select HDD regenerator>enter
    wait create it auto mode
    2.Enter(If you have one HDD)
    3.Press "1"ENTER for scan and repair (With out lose any data)
    4. press 3 for REGENERATE ALL SECTORS
    I will sugest press for "1" and enter
    press( 1-9 )any one number and type mb and ENTER
    Repair will Start soon.
    Insert a pen drive
    Restart your laptop and boot from cd
    1.Boot from cd
    2.Select mini windows
    3.you can explore every drive (hitachi) and can copy paste to pen drive.
    ALL IT WILL BE POSSIBLE IF YOUR HDD CAN SPIN AND AND READ .
    Hope this helps.
    Shibuda,
    If you are helped you can rate on the 4 thumbs and leave a short comment,because,
    this is the free side and I can get the chance, to help people like you .
    Jan 18, 2011 | Hitachi Travelstar 5K500.B...
    GA-8s648fx scanning bios image in hard drive
    update the bios of motherboard, it seems that the bios file is missing somewhere and now the computer bios is searcing for it ..(on Hard drive)
    so reinstall or update the bios it will fix the prob. otherwise if u say that the bios is working ok, then go to the bios and turn them to their Defaults, and restart.
    good luck
    shafky
    Jun 13, 2009 | Gigabyte GA-8S648FX Motherboard
    HP Pavilion dv4-1135ee ,BIG PROBLEM PLZ SOS
    the reason why this happen is that by mistake u have damage the MBR of the new partion u have created. the only way to fix the system is to format the entire system (entire harddrive) using DM thats the only way to fix it.
    Dec 23, 2008 | HP Pavilion dv6000z Notebook
    Hard Drive Data Recovery
    With file recovery program like asoftech data recovery, hard drive data recovery becomes an easy job. download the program from
    http://www.asoftech.com
    Dec 26, 2007 | Computers & Internet
    Gigabyte GeForce® 8500GT, PCI Express Graphic Card Logo
    198 people viewed this question
    Top Gigabyte Computers & Internet Experts
    David
    David
    Alun Cox
    Gbenga
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
