Question about Nokia 6300 Cell Phone
Navigation key how do i fix my navigation button on my nokia 6300 i cant scroll down or right!
Nokia 302 change language
Find "Device language"
  • Press the Navigation key.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Device and press the Navigation key.
  • Scroll to Language settings and press the Navigation key.
  • Scroll to Device language and press the Navigation key.
2. Select language
  • Highlight the required language and press the Navigation key.
3. Exit
  • Press Disconnect to return to standby mode
Jul 06, 2014 | Nokia 6220 classic Smartphone
My nokia 6300 alarm sound is very less i want to increase it if possible please tell is their any process to increase it.
Press menu button.
Select settings.
Select tones.
Scroll down to ringing volume.
Use right scroll to increase bargraph to maximum
Jan 27, 2011 | Nokia 6300 Cellular Phone
How to increase the ringing volume of nokia 6300
Press menu button.
Select settings.
Select tones.
Nov 12, 2010 | Nokia 6300 Cellular Phone
How do i copy contacts to the simcard without doing it one by one
Hi. Open your phonebook, press "Options" then scroll down to "Mark/Unmark" then press right navigation key and select "Mark All". Press "Options" again, scroll down to "Copy", press right navigation key, then select "To SIM Directory".
Aug 19, 2010 | Nokia E63 Cell Phone
I have a Nokia E71 and using SIM from my old mobile phone to transfer contact directory to the E71 phone. I have contacts in SIM directory and put my SIM card in new E71 phone. I still could not get a copy...
open "address book", then press "option"scroll down to "SIM contacts" and press the right-navigation key and select "SIM Directory"
It will display contacts on your SIM card. To copy contacts from SIM to phone memory. Select "Options" then scroll down to "Mark/Unmark" press right-navigation key and select "Mark All" then select "Options" again and then select "Copy to Contacts"
That will copy your contacts from SIM to Phone directory.
Apr 22, 2010 | Nokia E71 Smartphone
HOW DO I INCREASE THE VOLUME ON NOKIA E63
Answer the call then scroll to the right to increase the volume of the earpiece. Scroll to the left to decrease the volume. You will see the volume bar increases or decreases as you adjust it. The scroll keys are also called the navigation keys. They are the ones used when you navigate the menu up, down, left, or right.
Jan 23, 2010 | Nokia E63 Cell Phone
How to use incoming call volume control
Press the right navigation key after answering the call to raise the volume and press the left navigation key to lower it. The navigation keys are the ones you use to scroll up, down, left and right.
Jan 05, 2010 | Nokia N72 Cellular Phone
I cant scroll down or accross on my nokia 6300"
hi... ur navigation button button n ur mobile might got damaged.... so u contact a authorised service provider an ask to replace th key.... so that ur prob might get solved... kindly rate me... thank you....
Jul 02, 2009 | Nokia 6300 Cell Phone
I have a nokia 6300 and im having problems unlocking it help me please
To unlock the keypad security press the central navigation button quickly followed by the star key on the bottom left. Do the same to re-lock it.
Jun 11, 2009 | Nokia 6300 Cellular Phone
When i turn my nokia 6300 on it scrolls thru contcts
It seems to me that u have some problem with ur key pad..so try to replace it..
Jan 08, 2009 | Nokia 6300 Cellular Phone
Nokia 6300 Cell Phone Logo
53 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
