Question about Toshiba Satellite Pro M10 Notebook
What function keys to adjust my LCD monitor?
My brother gave me his toshiba pro satelite m12. i dont know how to adjust the LCD monitor (color, sharpness, brightness, etc.) i could not ask my brother about this coz he's on a plane going to abroad. will you please help me out aboout my problem. i will treasure your assistance and kindness.
  • jenre Jul 05, 2009
    thanks, fixer1950.i appreciate your help. but, i think the laptop itself is defective. have to look for a technician. godbless...
    President:
  • 2,976 Answers
Use the fn key along with the f keys. There should be a picture either on or above each f key
Posted on Jul 02, 2009
Toshiba satelite L305-s5968 need my screen to light up
Try FN+F5 after you power up. Hold down the FN key and press F5 This will toggle between the internal LCD and the external monitor output.
Jun 10, 2014 | Toshiba Satellite Computers & Internet
Toshiba satelite pro red spot on screen
Sounds like your screen is going bad or your video card is bad. Try plugging an external monitor to the laptop to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and plug it into the laptop. if the borrowed monitor displays without the red spot then your original monitor is bad. If the borrowed monitor shows the red spot then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 12, 2012 | Computers & Internet
My TOshiba satelite pro L300 in not continuing to windows,the screen is black i think its hanging up..were trying to reformat it but its not successful.I dont know if it had a bad sector in hard disk. but...
Hi
When a computer powers up the basic control program (BIOS) first addresses the graphics, then the CPU, then the memory, then the hard drive, then other devices.
If you see nothing at all on the screen, then it is probably a problem with the graphics card.
Check the lights on the front of the laptop. If you see a power light but no activity on the hard disk activity light, then the boot is failling at the 1st stage, before it even reaches the hard disk stage. this means a graphics problem.
If the hard disk was preventing the computer from biooting you would see the first 3 parts of the boot procedure on the screen before it stops at the hard disk stage.
Remove the battery. Connect the power cable without the battery and try to boot. If it boots, the battery is the problem.
Connect a desltop PC VGA cable to the laptop's VGA port and connect it to a desktop PC monitor and send the image to the external monitor by pressing th Fn key simultaneously with the Function key with a picture of 2 monitors (normally F5, F6 of F7). If the image appears on the external monitor, the graphics card is ok.
If the graphics card is OK, then the problem will be a faulty LCD Panel, LCD Panel Power Inverter or LCD Panel Cold Cathode backlight. If not then the problem is the graphics card.
Ask a technician to test and replace any of these faulty parts, if necessary.
If it is the graphics card, then the repair is either Ball graphics Array Reflow or Reballing, both of which can be expensive, have a marginal success rate and the fault can reoccur after repair.
Only a specialist with an Infra Red workstation can fix the graphics card,. typical repair warranty is 3-6 months. If it's too expensive to fix, it may be better to buy a new laptop.
I hope this helps.
Aug 24, 2011 | Toshiba Satellite Pro L300 Notebook
(Toshiba Satelite Laptop- Panasocic Viera TV) After connecting the Laptop to TV, via HDMI cable, nothing is displaying on TV. What settings do we need to use, to configure the two?
First you may want to go to the TV's menu and select the input to which you have plugged in the HDMI cable.
Second, on the laptop you will have to press a key combination to change the display from the built-in LCD screen to the external output.
It is Fn + F5 on most Toshibas, you will have to look for a function key with an icon symbolizing a internal/external screen like this:
It works like a 3-way toggle; when you hold the Fn key and press F5 repeatedly it circles through the following options:
- internal LCD only
- internal LCD + external monitor (both)
- external monitor only
If you want to see the picture on the LCD as well, you have to stop at the "both" option, but the resolution will be limited to the one of your laptop screen.
If you want to use the full resolution of the TV (like Full-HD) you need to stop at the "external" only and adjust your laptop display settings to optimum/maximum resolution for your TV.
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Computers & Internet
Just say unable to clean 35. nothing is working
Hi there you can try this not know if it will work for you but it works with some brother printers
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times until the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. Press the stop/exit key to return to the initial stage of the maintenance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2010 | Brother MFC 490cw Color Inkjet...
Can not figure out how to use projector with laptop.
maybe you need make a configuration in settings f2 or f12 to avaliable the vga port out
Sep 16, 2009 | Toshiba Satellite 1405-S151 Notebook
What is the compatible ram for my toshiba satelite pro m10?
go to tigerdirect.com...find 1-800 number call them they will know what u r looking for
Jul 18, 2009 | Toshiba Satellite Pro M10 Notebook
Samsung series 5 500lcd tv just black & white colors.
thanks for rapid comm.resolved issue .stb is a old version ,does not support hdtv ,changed to a newer version,everything worked fine.once again thank u
Nov 29, 2008 | Samsung LCD PREVIEW MONITOR f/950 AND...
Dual monitors
Most laptops have a function key to set which monitor is active. By toggling this key, you switch between laptop screen, external screen, and both.
On the keyboard, the key is usually Fn pushed together with one of the function keys that has a monitor logo above it.
Jul 22, 2008 | Intel Motherboard
Toshiba Satellite A135-S4527
LCD not displaying screen, correct. If you have a external monitor like from a desktop, then you can attach it to the laptop. Most laptops have a VGA or DVI connector on them. Even HDMI on new laptop. Most laptop have a combo you need to push to have it go the external monitor. It usually has Fn (Function) then above the F1-F10 keys in color, are the Function keys you push to get it.
I've seen it on F3-F4 keys normally. Your might be different. Use them as a reference only.
Let me know
comier957
Jul 14, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite Pro M10 Notebook Logo
138 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
