What are the instructions re water drainage, I cannot find the manual
  • 83 Answers
Basically the drain pan should tilt towards the drain itself. This so that water would not leak inside. It goes for split type and window type aircon.
I hope this helps
Posted on Jul 02, 2009
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
http://s3.amazonaws.com/szmanuals/b0348062b23e23cd40550b61e1dc5f43
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
Getting a E04 error code
According to siemens website Laundry appliances use many different codes depending upon age and origin. Faults that can be dealt with by the user are normally listed in the instruction book. Link to instruction manual download Flashing LEDs or displays frequently indicate door not closed, low water pressure or a blockage in the drain pump, drain hose or your drainage system.
Dec 09, 2013 | Siemens WFXD5200UC Front Load Washer
Lg tromm washer
Not enough information about problem but Laundry appliances use many different codes depending upon age and origin. Faults that can be dealt with by the user are normally listed in the instruction book. Link to instruction manual download Flashing LEDs or displays frequently indicate door not closed, low water pressure or a blockage in the drain pump, drain hose or your drainage system.
Dec 09, 2013 | Washing Machines
Dear my washing machine is product from italy made siemens wash and dry its showing E14 errorr please advise me what i can atcvally
Dec 09, 2013 | Siemens Washing Machines
My washer has a LD in the minute screen how do i get this off
LD is an error code relating to poor drainage. Check the drain hose and/or pipe for a clog. It's also possible that debris could have worked itself into the drain pump, causing a delay in drainage. Fixing your drainage problem will fix the LD error code.
Jun 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you clean a Bosch B25L (TDS2510GB) using the calc'n clean facility?
THE LINK DOESNT SEEM TO WORK SO HERE IS THE INSTRUCTIONS FROM THE MANUAL.
Calc'n clean
Cleaning the Boiler
To extend the life of your steam generator and to avoid any build
up of scale, it is essential that you rinse out the boiler after several
hours of use. If your water is hard, increase the frequency.
Do not use descaling agents for rinsing out the boiler, as they could
damage it.
1. Check that the appliance is cold and unplugged for more than 2
hours, and that the removable water tank (1) has been removed
from the steam generator.
2. Place your appliance on the edge of your kitchen sink.
3. Unscrew the boiler drainage plug (15) located on the bottom of the
appliance using a coin.
4. Holding your steam generator in an upside down position, and using
a jug, fill the boiler (in the base unit) with 1/4 litre of water
5. Shake the base unit for a few moments and then empty it completely
over a sink or bucket. To obtain the best result, we recommend
that this operation is done twice
6. Important: before reclosing, make sure no water remains in the
boiler.
7. Replace and tighten up the boiler drainage plug with a coin
Dec 27, 2010 | Bosch Irons
Leaking water on floor, even without water hooked up. Seems to be coming from under the fridge
Your freezer defrost drainage tube may not be routed to the evaporator tray under the refrigerator. If this is the case, humidity condensed from the freezer, then drained down the tube will be dripped onto the floor.
The second theory is that the drainage tube could be blocked. Humidity in the freezer is removed from the air sent to a drainage tray, at the rear of the freezer, which has a drainage tube which carries the water to an evaporation tray at the bottom of the refrigerator unit, on my GE. if the drainage tube is blocked, the water will find another route. Check the drainage tube after you find it. First try inspection. if there is standing water in tray in the freezer, use a flexible wire to clear the tube.
Oct 04, 2010 | GE Profile TPX24PBDCC Side by Side...
Hi, I have a Convair TRB portable air conditioner and I dont have an instruction manual. I'm wondering about the drainage outlets on the rear of the unit. The top one (half way down) has a black tube...
No the bottom hole should not be plugged. the bottom hole is the drain for the condensation. If you plug that hole the water will fill up and damage the unit.
Jan 31, 2010 | Heating & Cooling
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
