Dell 19" flatscreen won't turn on. 3 years old. Fine when I turned it off last time. Checked cables, fuse, connections: all seem fine. Do they give up the ghost?
  • 822 Answers
It will not turn on if power supply damaged. check primary and secondary supply inside check budge capacitor and the regulators output.
Posted on Jul 02, 2009
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
02 ZX9 turns over but won't fire.
Hi, Erik and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
zx9r won start
What to do When Your Motorcycle Won Start
Kawasaki Ninja ZX 9R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 06, 2017 | 2002 kawasaki ZX-9R
Last year my gable fan seemed to work fine. I
As it's protected by circuit breaker it also might be fused, so check for fuses.
Next just dig to the wiring and measure the resistance betveen Live and Neutral using simple multimeter. If there's no reading then there might be a small fuse (or thermofuse) attached to the windings, make sure this one is fine, if yes then motor windings are burned and you'll need new fan, otherwise just replace the fuse.
Good luck
Jun 24, 2009 | Gable (53315) Wall Mount Fan
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Heat worked fine all winter. Turned on A/C and blew a fuse. Replaced 3amp fuse and worked for a few minutes and blew another fuse. Checked all connections, filter, obstructions, need help...
If your blowing fuses then you have something grounded or shorted. By grounded I mean a wire has come loose and is touching the cabinet or a part that allows it to go to ground or your motor, capcitor or compressor is shorted.
Apr 25, 2009 | Heating & Cooling
Possible electrical short, batteries drain
ok stay with me. Buy yourself a 12V test light. Disconnect negative side of the batt. You might need 2 people for this. With test light connect ground wire to disconnected batt cable. Touch pointed end of test light in battery open terminal. If it lights up, you have a 12V drain in teh system. Now, most times you remove ONE fuse at a time and reinstall till the light goes out. MAKE SURE ALL DOORS ARE CLOSED AND EVERYTHING ELSE OFF. One you determine which circuit it is, .the fun begins. What on that circuit is draining the battery ?
Mar 31, 2009 | 1991 Pontiac Firebird
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
Alun Cox
David Payne
David Payne
