Question about LG Heating & Cooling
C6 error on neo plasma LG
New split system will shut down and then will not work or turn off. This usually happens after 2 hours sometimes more sometimes . It comes up with C6 and you have to turn off at circuit board.Tech came out twice ,first tome replaced the board -the second he replaced the condensor. The unit is exactly the same, just comes up with c6. He told me there is really not any more he can do . Very dissapionted and infuriated.It is not 12 months old yet.
  • jbell536 Jul 02, 2009
    Thanks sailor I will tell LG. You know what people are like when it comes to warranty work,aviod it like the plague!
  • 400 Answers
There are two reasons for this one is that there is a "DC PEAK ERROR" meaning that there is a communication failure between indoor and outdoor pc board and not a condenser failure. The second could be that the indoor outlet sensor is faulty or is being missed by the intergrated circuit board. Either way I would look at the indoor pc board replacement. Hope this helps
Posted on Jul 02, 2009
Please get some technicians that actually know what they are doing. we have had two also and say there is no problem. they dont have to sit in the heat for two hours till it comes back on. we paid top doller for this and this is what we get. what has happened to quality these days.
Posted on Dec 23, 2012
  • Ally Parker
    Ally Parker Jul 31, 2014
    Personally I would never by an LG split system ever again I have nothing but problem after problem with mine and absolutly no help from the company they are extremely difficult to deal with and continually give the run around, I have had two local companies also say to me that they refuse to do any service work for LG for the same reason.
LG neo plasma error code
It means the lid is open OR it has a short circuit.
Jul 08, 2015 | LG Asmc183vm Neo Plasma Filter
I have an LG neo plasma airconditioner and suddenly it turns off after about two minutes and it comes up with a code C5. Can anyone help please
Comms Error: check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
Dec 31, 2014 | LG Heating & Cooling
C6 error code
Check capistor and gas leaking
Dec 02, 2013 | LG LSC121PMA Split System Air Conditioner
Hi. I have an LG Neo Plasma Air Conditioner. Some time ago it started cutting out (switching itself off) and giving a C6 error message. When this happens, the remote does not work and the unit needs to...
Looks like a possible communication error. If you're willing I got one idea for ya. Turn power off to unit. The indoor and outdoor unit are connected and "communicate " through 4 wires, these are labeled 1,2,3,4. They should be color coded inside and out. Meaning if the color black is on 1 outside it should be on 1 inside. But, regardless, at the outside unit swap 1 and 4...2 and 3. Do the EXACT same thing at the inside unit. Then turn the power back on. I have ran into communication errors on mini splits simply because the "data" wire had a little nick or some kind of extra resistance that would throw a communication error but will work just fine as a supply voltage wire. Hope it fixes the problem. Good Luck!!
Apr 06, 2017 | LG Heating & Cooling
Our airconditioner has the code C6 on it. It has cut out and displayed that code. We were instructed to turn it off at the power board and turn it back on, which we did. It went back on again and tried to...
I previously asked you, if the C6 appear on the unit or on the hand held remote. I contacted a friend of mine who is a service technician for the LG Split System units and he advised that it's an error code that can only be solved by a LG trained service tech or LG itself. It may have been caused by a power surge, which may have caused some damage to the circuit board.
Sorry I couldn't be of more help.
Feb 03, 2011 | LG LA185HV Split System Air Conditioner
When running on cooling, runs for ten minutes then shuts down showing error messgae C6
C-6 Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. Split = text 21
Dec 14, 2010 | LG Heating & Cooling
Lg invertor air con "neo plasma"
i have the same, only way to get goin is turn off at mains. ive now tried running on fan low .... got this tip from another problem and seems to work.
good luck
Nov 04, 2007 | Computers & Internet
Heating & Cooling Logo
2,355 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
