Question about Sharp Office Equipment & Supplies
Sharp ar287 error code F2-00 what is the problem? when machine start to print, it show F2-00 then it stop. paper has reached drum and half of it has been printed.
    Problem Solver:
  • 5 Answers
Toner problem, most especially try to change destination of that toner being fixed on the machine
Posted on Jul 04, 2009
Why is my sharp mx 3500n copying blank pages. No error code indication
check the transfer roller/transfer assy or replace the drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 28, 2015 | Sharp Office Equipment & Supplies
What does code DY means and how can I fix it
DY THE DRUM CARTRIDGE PRINT COUNTER (YELLOW) REACHES 60,000 SHEETS OR THE ACCUMULATED NUMBER OF ROTATIONS OF THE DRUM (YELLOW) REACHES 715K
If your machine is displaying one of these codes let your service provider know. The codes indicates that the respective drum cartridge has reached it's maintenance or replacement interval. The machine will continue to print normally but you may experience copy quality problems on your printed pages. When the service has been performed the service provider will reset the counter and the code will stop being displayed. In some cases, the machine may be set to stop printing when this code is displayed.
Oct 16, 2014 | Sharp MX-2700N Color Copier
Error Code P-04-513
P04-513 is an ink overflow error.
the easiest way to fix it is to run the drum dry.
here is how:
1. turn the machine off by the power swith.
2. hold the left and right print position buttons and turn on the machine.
3. when the machine starts it will show you some numbers.. perss either the clear or yellow reset button to show 0000
4. now enter 81 and press start and the machine will make a master.
5. once the machine is done press the clear or yellow clear button to return to 0000
6. next make suer you have plenty of paper and enter 888 and press start.. the machine will start making copies of the test pattern. (if it jams a lot you may want to use speed 1 or go to step 4 and use code 80 instead)
once the copies start coming out light you can press the stop button and when the machine stops turn it off and back on normally.
Dec 19, 2012 | Riso RZ390 Duplicator
Error code PO4-513 on rz 390. overflow problem. I've seen the drum taken apart and cleaned out. any step by step instructions?
There is a much easier way to solve this problem. get a reem of paper and put it in the machine.
next turn the power off hold down the left and right Print Position arrows and power up the machine.
when it boots it will show u a number. at this point you can let go of the arrows.
press the yellow clear button 1 time and the machine should show all zeros on the display.
enter the code 80 and press start. the machine will make a master. after that it will show you 80 again.
press the c button at the bottem of the keypad and it should show 0000 again.enter 888 and press start and set the print speed to the slowest speed possible. (if it keeps jamming try pressing stop and repeating above steps but with code 81)
this is the ink drainage mode it will keep printing until you press the stop key.when the image starts getting light press the stop key and turn the machine off and then on again. and the code should be gone!
Jun 22, 2011 | Riso RZ390 Duplicator
Code dk
Your black drum counter has reached 50,000 copies. The drum has reached the end of its' rated life. You should print Sim 22-6 and see which other internal supplies need to be changed out. Drums=50K, Transfer belt and fuser=100K; paper and doc feeder tires=100K to 150K.
Sep 20, 2010 | Sharp AR-C260M All-In-One Printer
Pages print with black linesshowing over about
Sounds like it will either be the drum/blade or the fuser unit.Try turning the copier off when copying just as the paper reaches the fuser.remove the 'jammed' paper from the copier carefully as the image will rub off.If the lines are there then it is more than likely the drum.
Oct 29, 2009 | Office Equipment & Supplies
I get a partial copy when using my Sharp FO 5600
Make a copies with something with a lot of print. open top cover when the paper is 1/2 way through the machine. pull out the toner & drum unit's look at the drum is there a full image on the drum but not on the paper then it is a transfer problum. If no image on the drum then we have a laser unit problum. There is a shutter that opens when you put the drum in & closes the top cover. it may fallin out of place. hard to git at or somthing is blocking the laser beam ( paper, dust bunnyies or fourn objest ) hope this helps let me Know
C.W.H.
Jan 29, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp ar287 HELP ME PLEASE!!!!
I may have the wrong machine in mind. can you repost this. I am not one to not admit they are wrong;
Apr 15, 2008 | Office Equipment & Supplies
"maintenance needed" after so many copies
I hate this machine. Right now I can't print. It tells me to change the tray when I try to print.
Mar 13, 2008 | Sharp AR-M162 All-In-One Laser Printer
Firmware upgrade
What version do you have now?
Here is the newest version posted on SharpNet:
Version H2.40 contains the following modifications: 1. H5-01 error detection changed from 3 successive errors to 5. (POD1) 2. “H3” errors eliminated when ICU detects E7-00 error.(PCU processing change) 3. Image rotate information retained during paper-out condition by specifying use of manual feed tray. 4. If L3-00 or L1-00 errors occur after upgrade, TC 26-59 settings must be changed. Refer to technical bulletin AR-337-001 R for instructions. AR507.EXE Contains all the files needed to upgrade the AR287/AR337 copiers using a PC, SCSI adapter, and 7 series Black & White Imager. (AR287 ~ AR507) Refer to Technical Bulletin AR-505-001. AR507.EXE contains the following files – ICU_H2_40.mot, ICU_H2_40.fd, PCU_H2_40.mot, PCU_H2_40.fd, OPE_H2_40.mot, OPE_H2_40.fd, and Flash5.1.exe
The firmware upgrade on these "toner bombs" is no walk in the park but I can walk you through it and provide the bin files and software. contact me at double-u double-udouble-u dot brianbell dot net for more information.
Dec 26, 2007 | Sharp AR-5316 Advanced Digital Imager...
522 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
