Question about Monte Cristo D-Day for Windows
D-day demo failure
When I try to start the Demo for D-day in vista it tells me it will only run on xp---98 and won't run in compatibility mode
I have XP and the qx3 software runs but it won't recognize the microscope
Before you run the program, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Dec 25, 2012 | Intel Play QX3 Monocular Microscope
I cant get printmaster gold to work on my computer. i have windows vista
Broderbund PrintMaster Gold 16.0 is not compatible with Vista.
Platform: Windows 98 / 2000 / Me / XP
You can try to use Vista compatibility mode to run older programs in Vista. There is not guarantee that it will work!!! Please take note:- **The installation of an older program to run in a newer OS may also crash your PC too.
Link to How to "Use windows vista compatibility mode" - Use at your own risk!
Good luck.
Dec 07, 2010 | Broderbund PrintMaster Platinum 16
Shift2 USB 2.0 rechargable digital photo album N W!
You can try installing it in "Compatability Mode" for XP SP2 and Run As Administrator.
Windows Vista or Windows 7, has problems running some older versions of applications, just because so much has changed under the hood from Windows XP days.
To configure the compatibility mode for an application, just locate the installation directory and right click on the .exe, selecting Properties from the menu.
Select the Compatibility tab: Set it for "XP SP2"
You can actually hoose to run the program in Windows XP compatibility mode, or even all the way back to Windows 95 compatibility.
Probably the most useful setting to start off with would be to disable the visual themes and desktop composition, if you can’t get things working. If you are trying to run a video game, you will often need to choose “Run this program as an administrator”. You’ll have to play around with it, but most likely you can get your application working this way.
Jan 24, 2010 | Audio Players & Recorders
Running vista ultimate 32bit. installed lego chess. Crashes just before game starts story mode.Can you help ?
System Requirements of lego chess:
Windows 98/2000/ME/XP
Pentium 166Mhz
4x speed CD-ROM drive
16MB RAM
50MB of free hard drive space
SVGA Video Card (capable of 16 bit colour, 640 x 480 resolution and DirectDraw compatible)
DirectSound compatible soundcard
2MB of video memory
MouseThis is not compatable for Vista Ultimate.Anyhow I suggest you to try in compatabilty mode:
  1. Open Windows Explorer.
  2. Location the application executable.
  3. Right click the executable and click the Properties option.
  4. Select the Compatibility tab.
  5. Select the Run This Program in Compatibility Mode option.
  6. From the drop-down list, choose the operating system you ran before upgrading to Vista.
  7. If necessary, select the option to run the program as an administration.
  8. Click OK.
Thanks and regards, Giridhar
Aug 16, 2009 | Computers & Internet
My game is loaded but when i click on the icon. it will not play?
Ok, from what I read on Microsoft, this software is NOT compatible with Windows Vista 32-bit or 64-bit. That was found directly from:
http://www.microsoft.com/windows/compatibility/Details.aspx?type=Software&p=School%20Tycoon&v=Take-Two%20Interactive&uid=&pf=0&pi=5&c=PC%20Gaming&sc=Strategy&os=32-bit
However, checking the company's website, it mentions that some games that normally won't run in Windows Vista, can be ran in a "compatibility mode" which mimics Windows XP. Follow these steps and see if this corrects the problem:
  1. Right-click the shortcut for the game.
  2. Click the compatibility tab.
  3. Check the box for "Run this program in compatibility mode".
  4. Select Windows XP SP2 (or Windows 98 if XP does not work) from the drop down menu.
  5. Click Apply
  6. Click OK
  7. Start the game
It should run in Windows XP SP2. If it doesn't you can try Windows 98 to be sure. If neither of these work, unfortunately, you may be unable to play this game.
Mar 04, 2009 | Video Game Consoles & Games
Pc game not compatible with my DirectX
This game is for Windows 95/98/ME. And you dont specify what is your problem. The game doesn't install? Or after installation, it doesn't run? What exactly happens?
Anyway, if you're having problems running the game, you can try to:
If you're on XP or Vista:
- Install latest Direct-X (9 or 10, according to your OS, on Win98 and ahead you can install up to Direct-X 9): http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&DisplayLang=en
- If on XP/Vista, right-click on the game EXE and set compatibility mode (select properties, then compatibility, and on "compatibility mode" select to run the program as Windows 98 (try all options to see if it runs on any) - and try also the checkboxes below, to run the game in 256 color mode, on 640x480 resolution and to disable "visual themes".
Also update your graphics driver to the latest version available.
Mar 03, 2009 | 3DO Might and Magic 8: Day of the...
Graphics.h
Ok there is a compatibility issue to run C++ on windows vista...
so try run C++ on compatibility mode [Right click on C++ icon, click on properties, than compatibility] change that to windows 98 or XP.
also try to re install graphics.h header file..
It will solve your problem.
Jan 24, 2009 | Microsoft Windows Vista Ultimate Edition
A game connot load
First check to see if its Vista compatible if it is not then you can right click on the icon that you use to start it then select properties. Then select the compatiblity mode for Windows XP use this icon to load the game ...
This shows Clueclub Pool running on Windows XP in 98 compatibility mode.
LOL
Dec 25, 2008 | Compaq Presario 5000 PC Desktop
Sandrew
You're probably not going to find one. Vista lets you run old programs in 'compatibility mode' - actually, so does Windows XP. TSometimes it works, some times not but it's worth a try.
To use, you have to...
  1. right-click on the games' shortcut (either located on your desktop as an icon, or in Start -> All Programs).
  2. Once you right-click on the shortcut, click 'Properties'
  3. click on the 'Compatibility' tab at the top
  4. under the 'Compatibility mode' section, check the box that says 'Run this program in the compatibility mode for:'
  5. then choose 'windows 98' from the dropdown menu
  6. click ok when done
Good luck and I hope this helps! : )
Jun 24, 2008 | Microsoft Windows Vista Ultimate Edition
Propellorhead ReBirth & Vista compatibility
Rebirth running on Vista - Solved !!!!!!!!
I'm running Vista Home Premium and have an old CD of Propellorhead Rebirth which I have not been able to run at all.
The answer is surprisingly simple.
1. Install as normal from the CD and leave the CD in the drive
2. Find the Rebirth folder in the 'C/Programs' directory
3. Find one of the demo songs in the installed program and create a shortcut of the demo song onto the desktop.
4. Double click the Demo song icon.
5. I am successfully running Rebirth on Vista by opening the program through the demo song
6. In addition, try right clicking the Rebirth desktop icon, then 'Properties' - 'Compatibility'
7. You should have an option for selecting XP compatibility from the drop down list of upgrade service packs. This made no difference to my situation, but may help others.
Good luck
Gaz
Jan 21, 2008 | Propellerhead Rebirth 2.0.1 (us920039) for...
Monte Cristo D-Day for Windows Logo
51 people viewed this question
Top Monte Cristo Video Game Consoles & Games Experts
James Wishart
Tom Chichester
john h
Are you a Monte Cristo Video Game Console and Game Expert? Answer questions, earn points and help others
