Question about Coleman Mach III Air Conditioner
Is not throwing out cold air. Cool air only. - Coleman Mach III Air Conditioner
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Get up top and remove the plastic shroud. Gently rinse out the condenser coils with a water hose (do not use high pressure). Make sure that there is a good flow of water coming through the entire condenser before buttoning it back up. This should help.
Posted on Jul 02, 2009
My car heater is not working its only throwing out cold air
You may have a broken blend door or control, blend moor is very hard to fix.
Dec 30, 2013 | 2004 Chevrolet Aveo
I have a GE model # AGV14AJG1 I bought back in 06..it has a problem staying on when it's around 95degrees or hotter. I blow cold air at first then it makes a loud noise then shuts down then blows again n...
Take a look at the air entering side of the outdoor coil. This is the side of the could that the outdoor fan blade pushes air through. You can see the air leaving side very well, but the air entering side not so easily. That side of the coil is probably dirty. If so, unplug the unit from the wall, and using a water hose, clean it by spraying from the air leaving side inwards. Some of it will not come loose and it may need to be taken apart to clean. If you can throw water on it and it cools, it's overheating for some reason. Also, the condensate water should collect under the outdoor coil to help cool it. So if there is a hole in the bottom that a plug used to be in, plug it and see if that helps.
Oct 07, 2017 | Heating & Cooling
ON THE THERMOSTAT THE DIAL HAS 1-9 WHICH NUMBER DO I PUT IT ON FOR IT TO THROW COOL AIR
Only guesssing try either way and wait tell the unit puts out cold air but it shuld put it out if you place it on 4-5 .. let me know
Jul 23, 2011 | Goldstar WG5000 Air Conditioner
I am writting to you because i am getting air conditioned problem in my Smart Fortwo 2003 passion. When i switched on the engine and pressed AC button twice RPM shows AC ON status, however it does'nt...
had same problem on 2008 smart.over winter by not using ac it was blowing cold air.recharge unit.it lasted the entire summer.i know this isnt a complete fix but saves you money
Apr 14, 2011 | Air Conditioning and Heat for Smart fortwo
My A.C. unit is not cooling my room like it was a couple of days ago it just throws out air that is not cold and when I turn it on it the air that comes out on cool mode is like the air that comes out in...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Goldstar Heating & Cooling
Friedrich Wallmaster is not throwing cold air.
I have the same problem - bought mine 4-5 years ago been suffering ever since - spent so much money on Friedrich and still using fans. Piece of ****.
Aug 21, 2009 | Friedrich M18CF Split System Air...
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
No longer blows cold air and the unit is only 15 months old
First please clean the air filter and ensure that there is no dust settled on the filter which could chock the circulation of air.
To throw cool air the unit got to **** the air from the room and in case the air filter is blocked with dust then there will be no cooling at all.
Please ensure the thermostat knob is turned to the desired cooling level and try running the unit.
Ensure there is no escape route for the cool breeze.
Minimize the frequency of the door or window opening in the area to retain cooling efficiency.
I am sure your unit will work on taking the above precautions before operating it.
Jul 08, 2009 | Haier CPRD12XH7 Air Conditioner
Cooling
Not knowing what region you live in, I can only guess that it may not be warm enough for the cold control to activate the compressor.
I live in N,W, Ohio and it has not even been close to needing an
A/C
May 27, 2008 | Haier Heating & Cooling
Coleman Mach III Air Conditioner Logo
214 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
