Question about Acer Aspire 2930-4661 Notebook
Movement of cursor using inbuilt mouse
I am having problems with inbuilt mouse it does not move freely.
  • 147 Answers
Clean your touch pad sensor by opening the laptop. The problem will get rectified.
Posted on Jul 02, 2009
Pen cursor moves in opposite direction than its suppose to
Use your pad in the other direction or invert the cursor movement in mouse settings......
Dec 26, 2013 | Monoprice 8x6 inches graphic drawing...
When ever i move my curser on the screen the the scroll button comes on how can i get rid of it
Troubleshooting a mouse that scrolls up and down uncontrollably depends on various factors. Possibilities extend from the class of surface to hardware problems or configurations.
Identification
A variety of laptop mice exist.
A mechanical mouse uses a hard rubber ball that rolls with any movement of the mouse.
An optical mouse uses an LED sensor to detect movement.
An infrared, cordless mouse requires and relays a signal to the mouse port found on the laptop.
The base of the trackball mouse remains stationary, while the trackball sitting on top of this mouse reflects all movement.
Function
A mouse depicts a device that controls the movement of the cursor or pointer on a monitor or display.
Product
Several reasons exist for a cursor to uncontrollably scroll up and down on a display.
Static electricity often initiates wild cursor reactions.
To solve this, use pre-moistened computer cleaning wipes to help control static electricity and clean electronic surfaces.
Bad batteries can trigger impromptu cursor movements in a wireless mouse.
Electrical interferences can also produce the scrolling effect. Radio, wireless or electrical objects may require removal from close proximity.
The mouse needs to stay in range of the receiver, meaning near the Laptop
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
Sep 25, 2012 | HEWLETT-PACKARD HP Smart Buy ProBook 4720S...
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
Mouse will not mover cursor but will right and
Does your mouse use a ball for movement?
Look at bottom of mouse. If so you could have a ditty unit. You can turn the ball cover counter clockwise and remove the ball. Clean the ball and the rollers inside the mouse. Replace the mouse ball and cover and retry the mouse.
Jan 28, 2010 | Computers & Internet
Mouse has a mind of its own. The Logitech Wireless MX 3200 keyboard is fine. But, the wireless mouse movement and cursor movement on screen do not sinc with each other. I cannot do precise movements and...
I know this might sound too simple, but I ahve found that if I do not make sure I am moving my wireless vertical and horizontal, but diagonally...It goes haywire...
Also; You might be able to adjust the sensitivity in your control panel
Aug 22, 2009 | Logitech Cordless Desktop MX3200 Laser...
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
Laptop computer cursor
Are you talking about inbuilt mouse of laptop? Yes, inbuilt mouse can be repaired in a service center.
Mar 26, 2009 | BenQ Joybook A53 Notebook
Cursor moving erratically
Sounds like your internal mouse maybe be malfunctioning and due to the pressure on the spacebar is causing the erratic movement.
To fix this you can enter your BIOS with the F2 key at startup.
Continue through until you find some input options to disable the internal mouse.
Jan 23, 2009 | Toshiba Tecra M1 PC Laptops
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Dell ms intellimouse vertical movement of cursor
open the mouse remove the ball you should see two support shaft for the ball check whether they are rotating clean them if you can
if they rubber shield of shaft is damaged try replacing them with valve tube you usually use in a bycycle tyre
clean the transistors standing near the shaft flywheel using a soft cloth
it will be fine
Dec 14, 2007 | Dell Microsoft Intellimouse
Acer Aspire 2930-4661 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
