Question about Palm Treo 650 Handheld
Software upgrade makes bluetooth unworkable
Have Verizon Treo 650. Palm website urged upgrade from 1.04 to 1.05a software. After upgrade the bluetooth pairing with a palm earpiece would no longer work. Pairing fails in middle of operation. Othes report same problem. Have done usual hard and soft resets. Palm no help. Verizon no help. Ideas?
  • John Bulcroft Nov 12, 2007
    Thanks for detailed response but ther has to be a simpler way. This reminds me of calling for a minor problem on my PC and having a tech in India telling me I must reformat my hard drive. Hopefully, someone out there can tell me how to make this fix without resorting to such drastic remedies. Thanks, but no thanks.
    forget it
  • 1,006 Answers
I think this can help you:
Treo 650 only
A zero out reset will regress a device that has non-volatile memory to its factory-fresh state. When done correctly, it completely rewrites your device's internal memory with zeros and ones, ensuring that any data is expunged. It should be used only if you want all information completely obliterated (example: you're selling your handheld, or you're sending it in for repair, and want to protect your privacy). Tungsten E2 note: a hard reset (above) produces the same results as a zero out reset - completely rewrites data on internal memory. No need to perform the steps below. Warning: A zero out reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a zero out reset unless you want to eradicate everyting.
Software upgrade makes bluetooth unworkable - spacer.gif HotSync note: Some third-party applications change the way your device backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
There are two ways to perform a zero out reset.
  1. Read through these instructions before attempting the reset. We made this method of zero out reset extremely awkward to perform, so that it would not happen by accident. You may need the help of a dextrous friend if you find it too difficult to do by yourself.
  2. Connect your device to its HotSync cable or cradle. The HotSync cable does not need to be connected to your PC, and it does not need to be connected to power.
  3. Press and hold the Power button and UP on the 5-way navigator.
  4. While continuing to hold Power and UP, press and hold the HotSync button on the HotSync cable or cradle. As you press HotSync, make sure your other finger doesn't slide to LEFT or RIGHT on the 5-way navigator; it needs to be exactly on UP during the entire process. Although you are pressing the HotSync button, a HotSync operation should not begin.
  5. While continuing to hold Power, UP and HotSync, press and release the RESET button on the back panel of your device (where's the reset hole?). This is very difficult to do with only one person; you may wish to hold the stylus in your mouth and use your hands to press Power, UP and HotSync.
  6. Release Power, UP and HotSync.
  7. If you did this reset correctly, the screen of your device will go blank, and you will not be able to turn it on. The charging LED will not light up, even if it's connected to power. It will appear to be "dead." (any other activity — such as the Palm OS logo or a rainbow-colored Boot Log screen appearing — means the reset was performed incorrectly; try again)
  8. Your device will appear "dead" for several minutes (up to 10 minutes). During this time, your device's internal memory is being reformatted. If your device doesn't appear "dead" for several minutes with the screen completely blank, the zero out reset was performed incorrectly; try again.
  9. After several minutes, your device will "wake up" and the Palm and Palm Powered logos will appear as if you had performed a hard reset. Eventually, you'll be taken to a series of screens to calibrate the touchscreen and set date & time.
    887_palmone.gifSoftware upgrade makes bluetooth unworkable - 887_poweredcircle.gifimg src= 887_touchscreen.gif
  10. If you want your handheld to remain in factory state, stop here. If you want to restore data to your device, follow the steps for recovering after a hard reset (a zero out reset is a special type of hard reset).
Quick Erase, Secure Erase
LifeDrive only When you perform a hard reset on a LifeDrive mobile manager, you will see two options on the reset screen: Quick Erase and Secure Erase. Both of these are types of hard reset. Quick Erase: Perform a Quick Erase reset for a regular hard reset, to get your device to wake up and respond again. This eliminates user information on the drive in such a way thaSoftware upgrade makes bluetooth unworkable - spacer.gif no info available to anyone using Software upgrade makes bluetooth unworkable - spacer.gif. A Quick Erase reset takes approxiSoftware upgrade makes bluetooth unworkable - spacer.gif5 minutes.
spacer.gif spacer.gif spacer.gif Secure Erase: Perform a Secure Erase reset if you are turning the device over to a new owner. A Secure Erase helps prevent your files from being restored or recompiled by a new owner who might remove the hard drive and use a drive reader to access your information. This completely deletes all user info on the drive. A Secure Erase reset takes about 30 minutes.
Note: If you use a password to protect your device, you must do a Secure Erase when you hard reset your device; the Quick Erase option does not appear on the reset screen.
  1. Slide the power switch to the right and hold it in that position.
  2. While holding the switch to the right, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button on the bottom of your device.
  3. Wait for the reset screen to appear (it will say "Warning, Erase all data?"). Then release the power switch.
  4. Choose your type of reset:
    • Press Up on the 5-way navigator to perform a Quick Erase (5 minutes)
    • Press Down to perform a Secure Erase (30 minutes).
  5. During the reset process, a status screen appears with the words "Quick Erase" or "Secure Erase" and a progress bar, followed by screens showing the Palm, Palm Powered and LifeDrive logos.
  6. Then you will be prompted to tap the screen to align the digitizer and select the language you want to use on your device. A screen appears showing the Palm logo and a progress bar.
  7. When the "Welcome: Setup your device" screen appears, the hard reset is complete. Follow the onscreen instructions to set up your device.
Posted on Nov 10, 2007
  • arben pllana
    arben pllana Nov 12, 2007
    Do u mean PC HARD DRIVER??? HUH BULL SHIT...
    i think the best way and fast way to fix ur problem is if u can be a memmber off !It is remote control.If u trust me like expert i will go througt ur pc and fix it..If u dont trust me soo...
    If u want to be memmber of logmein so send in my email adrese details : username password and windows acess password and i make u sure ur problem will be fixed...
    Have a nice trip
I am using Windows 7 and want to Hotsync my 1000s of Memo Notes from My Palm Treo 650, I got the latest Palm Desktop and Hotsync Manager but My Computer cannot Hotsync or even detet my Treo 650....Pls...
Palm Desktop compatibility with Windows 7 and 64-bit editions Palm Desktop 6.2 was designed for 32-bit editions of Windows XP and Windows Vista. You may be able to use this software with other versions of Windows.
Windows 7: Many users have successfully installed and used Palm Desktop 6.2 with Windows 7. Palm has not done thorough testing with a range of third-party equipment running Windows 7, therefore Palm cannot guarantee compatibility.
64-bit editions of Windows: USB HotSync is not supported. Instead, synchronize through a Bluetooth wireless connection: set up Bluetooth HotSync.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 18, 2010 | Palm Treo 650 Handheld
Treo 650 reset itself and the phone app seems to
plz re-install da cell phone software...the old one is damaged badly
Nov 14, 2009 | Palm Treo 650 Handheld
Unable to Synchronize with Vista 64 bit
Treo 650 can't be synced to Vista 64 via the cable, but Bluetooth works OK. Details later (I hope).
Apr 28, 2009 | Palm Treo 650 Handheld
Palm Treo 650 unlock code needed, used to be with Verizon
yes we can unlock just join me on yahoo id : cellularhut_rajan
Oct 30, 2008 | Palm Treo 650 Handheld
Vista hotsync
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Oct 26, 2008 | Palm Treo 650 Handheld
Palm Treo 680 won't upload to Vista
Sep 03, 2008 | Palm Treo 750 Smartphone
Unable to hotsync treo 600 with my computer
What is happening with the Sync? Does your PC and the Palm Desktop Manager recognize your TREO 600? If not, the issue may be that somehow the driver for your device was removed. I would suggest upgrading to the latest version of the Palm Desktop Manager and try plugging in your TREO 600 again and try synching.
Here is the location for the free software from Palm.
You also have to make sure that the setting on the Palm Desktop Manager is the same as the type of cable you are using. If it is a USB cable, have that setting on your PC's Palm Desktop Manager Hotsync settings.
Jan 27, 2008 | Palm Treo 600 Handheld
ye it is just press 1 as your pass key and 1 as the pass key on the moto sliver
Oct 27, 2007 | Palm Treo 650 Handheld
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Sep 22, 2007 | Palm Treo 600 Handheld
Synching treo 650 with 600
In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
Sep 11, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
268 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
