Question about Seagate (9W2892-337) 80 GB Hard Drive
How to make win98 bootable Harddisk?
I want make HDD bootable without using sys command or format command. Can I use copy command or something else for that ? Please help me.
  • 147 Answers
Make a bootable floppy.
and then copy all the files of the floppy to the c drive of the hard disk.
Posted on Jul 02, 2009
I want to format my Flash disc using Dos command tag, and at the same time inserting file system in it, How can do it? and Help me with the command
the way to format in DOS at the command line level is as follows:
At the command prompt type:>format d: /sys
Where d: is the letter assigned to the flash drive(it may be efgh,etc..) then spacebar and /
where / is a switch and (sys) is the file you want to copy
sys = system files
Hope this helps
Mar 03, 2011 | Office Equipment & Supplies
Cant install windows
System will show CD as C: and "COPYING" doesn't make drive "BOOTABLE".
You have to let the restore CD do the whole process of FDISK, FORMAT and INSTALL.
If you want HD bootable with no "WINDOWS"
use this command at A: prompt.
FORMAT C: /S
I'd have to get out my Win/DOS notes for more.
Try "Help Format" if that doesn't work.
I would Let the CD do everything if you are not familiar with DOS installs.
Apr 08, 2010 | IBM ThinkPad A22e 2655 Notebook
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
c:\win98/win
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
Reformatting acer 8730
To format the pc you have to use the Bootable OS cd ( 98 0r Xp )
If you are using 98 then you have to insert the 98 bootable cd into the CD drive set the boot sequence in the BIOS to boot from CD optionand restart the pc after restarting you have to identify the cd-drive letter which also appears at the command prompt here you have to browse the cd using dir/p command and then change to win98 directory using cd win98 here at the prompt(>) type format C: if C is the drive letter of the Harddisk
(2)If you want to format Using XP which is much easier than the previou procedure insert the XP cd and restart the system continue with the installation procedure of xp at one stage it will ask for to select the drive where you want install the xp select the drive and that particular drive will be automatically formated after format it will restart at that time you can remove the cd and exit the installation
If you want to completly delete all the harddisk partition and create new partitions you can do that using the Disk manager cd( PC can be formated and create new partition using Bootable XP also)
I am sorry if these procedures are to much
May 03, 2009 | Computers & Internet
Massstorage
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
Required:
· USB Flash Drive (4GB+)
· Microsoft OS Disk (Vista / Windows 7)
· A computer running Vista / Windows 7
Step 1: Format the Drive
The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
Plug in your USB Flash Drive
Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
Find the drive number of your USB Drive by typing the following into the Command Prompt window:
diskpart
list disk
The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
select disk 1
clean
create partition primary
select partition 1
active
format fs=NTFS
assign
exit
When that is done you’ll have a formatted USB flash drive ready to be made bootable.
Step 2: Make the Drive Bootable
Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
Insert your Windows Vista / 7 DVD into your drive.
Change directory to the DVD’s boot directory where bootsect lives:
d:
cd d:\boot
Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
bootsect /nt60 g:
You can now close the command prompt window, we’re done here.
Step 3: Copy the installation DVD to the USB drive
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
Step 4: Set your BIOS to boot from USB
This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
Jan 23, 2009 | Computers & Internet
How do i format my novatech B750
Just use a bootable CD and boot up with it, you'll come to a stage where you're asked to format your HDD.Or bootable flopy disk, when in command prompts you type format e: and press enter Or you could remove the HDD and use a external USB casing and use other PC to Quick format your HDD. Note:If you're trying to format your Laptop HDD, I will suggest that you get the all driver information for the hardwares before installing a new operating system. Because when new fresh installation is done you will be asked for the drivers for CD-rom, key board etc...
Nov 13, 2008 | Computers & Internet
HOW TO BOOT
If you have access to an external drive enclosure, OR you have a computer you can put the hard-drive from
that machine in temporarily, put the drive in one of them and copy the WIN98 directory to the harddrive.
Once the WIN98 directory is there, you can just install it from there. That is of course if the hard-drive has been
formatted with the /sys command, and set to primary boot drive using FDISK. As far as installing from floppy,..
the floppies haven't been on the market for a LONG time, and if you have them,.. I imagine they've seen better
days. If you HAVE to install from floppy though, use another computer, put in the CD, open the cd using windows
explorer. Once here, click on the WIN98 directory, and locate the files you need ( too many files and directories
to list here ) Seriously the best way would be to use an external drive enclosure ( since it's probably a 2.5" drive
size ) and just copy the whole directory to the drive and forget the floppy idea. It will take MUCH less time.
Feb 25, 2008 | Compaq Armada E500 Notebook
Format a corrupt system without 98 bootable
Basically yes. You need to remove the HD from the PC without any bootable devices and install it as a slave to a second PC preferably also Win98.
You can then proceed to format the HD (as FAT32) of the 1st PC on the 2nd PC. Sys that HD to transfer system files and make it active. To facilitate installation of the OS, create a folder on that HD and copy the Win98SE installer files into it. Remove that HD from the 2nd PC and reinstall on the 1st PC. Power and it will boot into Dos.  Go inside the folder where the OS installers are and run "setup".
Alternately, you can just clone the HD of the 2nd PC to the corrupt HD of the 1st PC after format  /s. Just make sure that you still have the Win98SE installers copied to the corrupt HD.
Hope this be of some help/idea. Post back how things went or should you need additional information.
Good luck and kind regards.
Oct 24, 2007 | Dell (6G040) Motherboard
Hard disk failure
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
May 05, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Seagate (9W2892-337) 80 GB Hard Drive Logo
60 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
