Question about Canon CFX-L4000 Plain Paper Laser Fax
Paper feed on send
When sending a fax it will no longer feed multiple pages one at a time but grabs two or three at a time. Have cleaned roller to no avail
  • John Bulcroft Nov 09, 2007
    No paper jams. I am talking about the pages I feed INTO the fax which are being faxed, not paper from tray used to print incoming faxes
    President:
  • 317 Answers
Have you checked that you have no paper jams?
Posted on Nov 09, 2007
  • Peter Burns Nov 09, 2007
    A paper jam sometimes isn't fully cleared (it can be difficult to find that
    last, tiny scrap of paper stuck in your fax), and the paper feed
    mechanism may break down. Open the device and check all of the housings
    and other mechanisms in the unit. Make sure each is clear of any
    impediment and securely close each one.
    It’s possible that the problem has nothing to do with the MFD’s
    hardware and can be fixed by adjusting the paper stack. Make sure paper
    is straight (no bent or curled edges) and that all the paper in the
    stack is of the same size and type. Check the manufacturer's
    recommendations for the number of sheets.
Brother MFC-3240C All-In-One InkJet Printer will not initiate when inserting a page to copy.
try cleaning the primary feed rollers with 99% alcohol. make sure mahine is unplugged and the rollers are dry prior to repluggin it in.
Feb 28, 2014 | Brother MFC-3240C All-In-One InkJet...
Multiple pages
Actually, when you get more than one paper feeding in at a time, it is almost always the separation pad being worn down. Go here to buy a new sep. pad and tell them Ken from National Cartridge Co. sent you there!
http://www.precisionroller.com/paper-feed-components-for-brother-intellifax-5750e/details_9248.html
May 28, 2010 | Brother IntelliFAX 5750e Laser Fax
Cannon laser fax 1060 P "check paper size"
Hi Margaret
Ok,the problem normaly with this model is in the feeding of the paper.For some or other reason the paper is moving to slow threw the machine and then the machine detect it as a longer size paper.
  • Clean the rollers that pick the paper up and clean also the sepatation rubbers under neath the paper pick up rollers.This rubbers is called the separation pads.
  • To clean this rollers,remove the cartridge and you will see the feed roller at the back.
I think what happened with the move the machine might collected dust and now the rollers are slipping.
Thanks for you support
Dec 29, 2009 | Canon L220 Plain Paper Laser Fax
Front loading page grab problems.
See that top on which to place paper faxing is a green button should be positioned (to the right or left) in position with several sheets drawn as an indicator. I guess yours is positioned on a single paper which means it does not separate anything you ask.
Good luck to configuration
Oct 30, 2009 | HP LaserJet 3200se Printer
Laserjet 3015 will not fax more than one page a time
Open up the document feeder and clean the roller and pad with alcohol.
Jun 08, 2009 | HP LaserJet 3015 All-In-One Printer
Pages sticking together when transmitting
This is caused by the feed and separator rollers are dirty or worn out. The simplest thing to try is to clean the feed rollers. you will need a cleaning solution, isopropal alcohol works very well. Available at local drugstores. you can approach this one of two ways, you can open up the document feed section and manually clean the rollers or put a few drops of Alcohol in the center of a piece of paper let it soak in a little and pass it through the document feeder, the paper should have a streak on the last half of the page if it made contact with the rollers. For best results do this a couple of times, for better results do both the manual and the pass paper methods.
Hope this is of some assistance.
Ed
Apr 20, 2009 | Panasonic PanaFax UF-8000 Laser Fax
When sending fax, the pages feed crooked
HELLO! YOU WILL NEED TO BUY SOME ISOPROHYL ALCAHOL, THE FEED ROLLER NEED TO BE CLEANED AS YOU HAVE A BUILD UP OF PAPER DUST
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
SF-3100 Paper feed problem
You need to clean the friction pad. If you open the part where you put your sheets in to send faxes you will see a white pad behind the cover. You need to clean it, if it still feeds more than one page the pad is probably worn.
Jan 09, 2008 | Samsung SF-3100 Plain Paper Inkjet Fax
Outgoing fax does not feed automatically
I don't know any specific info related to the panasonic fax, but here is some "general" information that is usually universal. The fact that the paper feeds "with some help" indicates that everything is working... just not as well as it should. Very often, a problem like yours can be rectified by simply cleaning the original take-up/in rollers with some alchohol (I usually use 90%+ rubbing alchohol as it evaporates quickly and leaves little, if any, residue) on a rag. Also, there is usually some sort of "pressure pad/roller" (sometimes called a retard pad/roller") on these types of machines that work in conjunction with the primary original paper take-up roller. It can be either dirty or worn as well. This should also be cleaned. If it's a pad type system, often it just clicks/clips into place, and can be removed, the rubber pad itself flipped over in the retainer, re-installed, and the "un-worn" side then faces the paper offering better pressure for feed, and preventing multiple page feed. Hope this helps.
Jan 27, 2007 | Panasonic KX-FL541 Plain Paper Laser Fax
Canon CFX-L4000 Plain Paper Laser Fax Logo
120 people viewed this question
old marine
old marine
