Question about Sewing Machines
The zipper on my Asos dress split and it is stuck
The zipper on my Asos dress split and it is stuck in the middle of the zip with both ends open. Now I can't zip it down
    New Friend:
  • 3 Answers
Hold the zipper that both sides are parallel then go upwards then downwards . Once u go upwards look it could be a little thread stuck in it .
Coz it's a plastic zipper it happens just get it replaced .
Posted on Aug 30, 2014
I haven’t used my machine for years and would like to know the tensions etc but I can’t remember which is the zipper foot
a zipper foot is one that is only half a foot
that allows the needle to get close to the zipper as for tensions
needle thread tension will be correct when you pull the thread just before threading the needle and you can feel resistance to pulling the thread
Nov 29, 2017 | Sewing Machines
Pattern 4070--I'm having trouble with F view--attaching overlay, dress and lining. Need to install zipper and it's not fitting correctly.
Take your project and the pattern instructions to the fabric store and perhaps one of the kind ladies will help you.
Apr 08, 2017 | Sewing Machines
Can you sew up the front of a button down front on a dress?
Yes you can. Be careful to remove the buttons. It could be nice to sow a decorative ribbon where you sow the front together. Good luck
Kolbrun
Mar 14, 2017 | Sewing Machines
Using an invisible zip foot my machine jams after a few stitches. It doesn't jam with any other foot, and when I sewed with the foot on a scrap of fabric with no zip as a test
Make sure that the needle is not too close to the zipper coils. Also, that the needle is not hitting part of the presser foot. Sounds like the needle is most likely encountering the zipper coils which are deflecting the needle. Move the coil further away from the needle.
Sep 04, 2016 | Sewing Machines
How do I fix a complete zipper
if you mean how do you sew in a zipper
do it up and then position in in the opening using pins to hold it in place while you sew it in
when finished you can open and close the zip and it will always be in line
Dec 06, 2015 | Sewing Machines
I am trying to insert a zip. The needle is not moving far enough to the left or right so that it doesn't hit the zipper foot. Please help
try using a 1/2 foot as this will allow the needle to get close to the edge or zip
commonly used for making a rope edge
available from any sewing machine shop
Aug 01, 2015 | Sewing Machines
Elna needle is not lining up with the zipper foot notches
You ought to be able to move the needle in increments from left to right. Check your manual or the Elna website for help.
May 20, 2017 | Sewing Machines
How to sew in a zip? with Empisal dress maker 270
Sewing in a zipper is a fairly easy process, though a bit hard to explain in words :) You need an iron, pins and a zipper foot for your machine. The zipper foot allows the needle to get close enough to the teeth of the zipper without the foot getting hung up by the teeth.
The best thing to do in order to understand the process if you've never done one before is to look a a video on youtube and watch how a zipper is put in. Here is one link that shows how to insert a zipper http://www.youtube.com/watch?v=ue5z2rWS588&feature=related ...but there are several others too. Some show specifically "invisible zippers", some show side seam zippers and others show how to put one in where you have a waste band. When you get to the link above look to the right side of the page where you will see other videos to pick from too.
There are lots of interesting sewing videos on youtube. You'll note that though the process is basically the same different seamstresses have different tricks for getting a straight and tidy looking zipper.
May 16, 2011 | Sewing Machines
Would you please advise how I put a zipper foot on my brother bm-3600, the needle will not align with the foot when I put the foot down! Thank you.
Did a google image search, this looks like a newish machine so I'd assume clip on feet?
Put the foot on the pressure plate, lower the foot on and align so it clicks into place.
Couldn't get an image of the foot but many zipper feet are designed to mount either left or right side of the foot so you can sew both edges of the zip in the same direction, ie pressure foot to left of the needle for one side, and to the right of the needle for the other side of the zip, you want to stitch in the same direction to avoid creeping.
Some machines you change the change the needle position to the left or right in order to get up close to the zipper foot.
Probably a manual would assist explaining this better, if you don't have one for the machine, I'd suggest that you obtain one.
Mar 07, 2011 | Sewing Machines
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
Sewing Machines Logo
118 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
