Question about IBM E54 (Pearl, White) 15 in.CRT Conventional Monitor
How to set screen resolution in acer x153w ,after restarting all the previous settings are gone.
  • 85 Answers
Right click on desktop, properties,settings then you can change the resolution.
Posted on Jul 02, 2009
How can i adjust my screen resulution of acer x153w in to 1024by768 pixel
Hi, you can right click the mouse on desktop -> select properties -> settings. You can easily find out the way to change the resolution
Jul 16, 2011 | Computers & Internet
How to increase the resulution of acer x153w in to 1024by768 pixel
eight click on desktop and select the last option of properties a new window will open select the last tab of setting now you can see a bar of resolution move it and increase or decrease your resolution
if the bar shows disable and not working
then put your system driver cd on your cd rom and install the video or graphics driver restart your computer now follow the first step now the bar is enabled and you can move the bar to increase or decrease your resolution
Sul monitor Acer AL1515 compare Input Not Supported
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor. What you can do is restart your computer to safe mode first. These are the steps going into safe mode:
1. Make sure your computer is off.
2. Turn on computer then tap F8 repeatedly once per second. Similarly, Windows advanced options menu should be up on you screen.
3. use arrow keys to highlight "safe mode".
4. press enter twice.
5. log on to your user profile
6. you will get a window asking you to press "yes" or "no". CLICK the YES button.
7. perform the next steps below according to your windows version (operating system)
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
NOTE: For Windows 7, it should be similar to the steps for Windows Vista.
Jan 16, 2011 | Acer X193W LCD Monitor
Al1716 monitor plugged unable to change resolution.
You need to set the PC resolution to the native resolution of this ACER monitor, which is 1280x1024 @ 60Hz.
Mar 10, 2010 | Acer AL1716 F Monitor
My Dell Dimension 4600 monitor has gone completely black though it shows it booting.
Start your computer in "Safe Mode".
Change the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, and restart.
If you eventually see your "wallpaper", try setting your screen-resolution to 1024 by 768, and "test" it. If OK, try setting your screen-resolution to 1280 by 1024, and 'test" it.
Jan 07, 2010 | Dell Dimension 4600 PC Desktop
Font size much too big on the screen
By "font", do you mean everything is large on the screen, including icons, and menus?
If so, your screen resolution might be set very low.
To increase the resolution (and subsequently decrease the size of everything displayed)...
Windows XP
1.) Right-click on the desktop and choose "properties".
2.)Choose the "Setitngs" tab.
3.)Slide the "Screen Resolution" slider towards "more"(the right) and click "Apply"
4.)Your screen will flicker and test the new resolution. If you like what you see, Click "Ok". If you do not, or your screen remains black, you can wait 15 seconds, and your screen will revert to it's previous resolution.
Windows Vista
1.) Right-click on the desktop and choose "Personalize".
2.)Choose the "Display Settings"
3.)Slide the "Resolution" slider towards "high"(the right) and click "Apply"
Hope this helps.
Sep 19, 2009 | Acer Extensa 5620-4020 Notebook
Problem with the increase the resolution of display from 800X600
Go to your desktop, find a blank space. Right click to open up a context menu. Near the bottom, there should be a "properties" tab. This will open up a display manager. Scroll through the tabs until you find one that has the resolution settings (probably the second from the left). There should be a small slider bar, just move that to the right or left to adjust your resolution. The computer may not allow you to increase the resolution above what the monitor can handle.
Jun 23, 2009 | Computers & Internet
Acer Travelmate2350 display flikkering
Seem that your screen resolution changed. Turn off the notebook and again switch it back press F8 until it shows a list of option and then select SAFE MODE. Select it and enter into safe mode.
After welcome screen Right click on Desktop and select properties.
You will get Display Properties window.
Then select the Settings TAB in Display Properties. There select the screen resolution as low as you can 640by480 or 800by 600 then select apply and restart the Laptop.
The notebool should work normally as previously it work.
Hope this will be usefull
Thanks & regards
Nanda Kishore.
Jun 09, 2009 | Acer TravelMate 2303WLCi Notebook
Graphics error
Hello, I dont think you need a driver for you lcd screen. If your resolution is low you need drivers for your graphic card. what card do you have ?or computer?
May 13, 2009 | Acer AL2017 20" LCD Monitor
IBM E54 (Pearl, White) 15 in.CRT Conventional Monitor Logo
557 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
