Question about Proscan PS36125 36" TV
My lcd tv has been back and forth since i have purchased it 5months ago,i have been told it is not faulty by LG however when i get it back it keeps switching on and off on me. i have had it working perfectly in three other households it just keeps switching on and off only at my place???
i have been told it is something to do with frequency so i tried with turning off the computer,microwave and even the house alarm still does not make a difference!!
please help very frustrating i have paid 5gs for a tv and cant watch it!
  • 86 Answers
If it works at 3 different houses, but not yours, then it might be the electrical wiring at your house. Try a different outlet in a different room. Make sure your electrical wiring is not too old, and needs to be updated. Check your circuit breaker panel, does it need to be updated?
Posted on Nov 09, 2007
Can't get HD on my TV. Tried with every cable type but cannot get High Def
2 things have to happen. first, your tv has to be set for the correct resolution, second, You need to be recieving high def from your cable/sat provider.Your tv does not make programming high def, it allows high def.
Mar 10, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Televison & Video
Whistling when TV is switched on. LG LCD 32''
If the sound is coming from the back of the TV, then the issue is with the power supply and may get worse causing the TV not to power on.
If the sound is coming from the speakers, then the issue may be with the main board, an audio hookup to the TV, and or a bad ground loop with the TV and the connections to it.
May 17, 2010 | LG 32LG30 32 in. LCD HDTV
Model LG52LG70 has a problem when switching from High Definition channels to non-high definition channels, and vice a versa. The tv simply shuts off, pauses for 10 seconds and then turns on. Time warner...
Any high def TV will momentarily go blank when changing from High Def to normal mode. Ten seconds is an abnormally long time for that to take place. If you still have a warranty on the TV I suggest you take it in to have it serviced. Otherwise you will have to pay to have this item checked out. There are a number of issues that might be causing the problem so it will be necessary to have a technician check it out.
Feb 18, 2010 | LG 52LG70 52 in. LCD HDTV
I have a shadow on my 47" LG LCC7DF HDTV LCD TV
This is usually caused by dirt trapped between the lcd filter layers and appears when the screen is pressed, pressing the layers togehter producing an internal dust smear..This can only be removed by stripping the lcd down and cleaning the filter layers
Oct 17, 2009 | LG 47LC7DF 47 in. LCD HDTV
Display delay
This is unlikely Verizon's problem.
Does the delay occur with non-TV sources like DVD player or video games?
If so, that's the LG firmware.
Aug 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
Audio cuts out
HDMI is not a universal standard. Some units will not talk back and forth correctly and can cause lock ups, loss of audio or loss of picture. Try switching to component inputs and see if it works better. Check your owners manual but I believe the component inputs will also accept 1080P as long as the Panasonic Blu Ray can output 1080P. Don't believe what the Salesman said if he told you that you have to use HDMI or you won't get HD.
Apr 19, 2008 | LG 42LB5D 42 in. LCD Television
Televison & Video Logo
104 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
