Question about Shure SM2 Professional Headset
Do I need a transformer in line with the Shure SM2 microphone cabling to my board to get output? I've looked at the schematics and I do not see a transformer in the SM2 mic however the SM57 and SM58 mics both have transformers before their xlr male connectors.
  • eboumeester Jul 02, 2009
    I saw the schematics and verified my connections, however the SM2 mic portion differs from the SM57 and SM58 mics and the difference may cause low output so to increase output will the use of an in line step up transformer help yes or no?
Have a Shure SLX Wireless System. The only way the microphone SLX1 or SLX2 is if they are right up to your mouth. If you put the lapel mic on a persons tie you can't hear them. The transmitter is set to...
The Shure SLX2 hand-held microphone has similar performance characteristics to the much-loved (cabled) Shure SM58 vocal microphone. It has a 'cardoid pick-up pattern' intended for close work - being spoken / sung straight into the top of the capsule at no more than about 8 inches from the mouth of the user- to minimise feedback and extraneous noise. If you double the distance between the mouth and microphone the sound level will drop four-fold so distance really matters.
The SLX1 lapel/ lavalier is a semi 'omni-directiona'l pick up pattern microphone, which should work satisfactorily up to 12 inches from the speakers mouth, but closer is better. Always try to get your users to hang it about 6 inches below their chin, at most, and preferably with the top of the microphone capsule pointed upwards towards the mouth.
Here are a few other things for you to try:
  1. There is a volume (gain) knob on the back panel of the SLX receiver unit. Try turning this up to maximum (needs a small screwdriver)
  2. Make sure that both aerials on the receiver are fully extended at different angles to each other and in a clear 'line-of'sight' with the transmitter pack, with no large bits of metal in between which could block the signal. Ideally the receiver should not be more than 25metres from the transmitter. If distance is a problem locate the receiver near to the transmitter and run a balanced (xlr) cable to your mixer/ amplifier.
  3. The angle that the receiver aerials are at should be broadly similar to the angle that the transmitter antenna is at to optimise signal reception.
  4. Make sure the receiver is not located too close to other electrical equipment which may be interfering with the signal (especially voltage transformers, CD or DVD players and hearing loop induction amplifiers which have a strong magnetic field)
  5. Always use good quality batteries - Duracell Ultra or equivalent ( do not use rechargeable batteries as they seldom achieve optimum voltage)
  6. Check that the antenna is tightly screwed into the SLX1 transmitter pack and not damaged.
  7. The SLX2 hand-held microphone has an adjustable level switch inside the body - unscrew the top of the microphone to access it - switch to maximum.
  8. Another possible cause could be an impedance mis-match between the SLX receiver and your amplifier or mixer. There are two outputs on the rear panel of the receiver. One is an XLR (large 3 pin socket) this is LOW impedance and needs connecting to a low impedance input on your mixer/amplifier. You should normally be using this output even if your amplifier has a jack-socket input (use a proper balanced XLR to 6mm trs jack cable rather than a adapter plug). The other output on the receiver unit is a 6mm HIGH impedance, unbalanced, standard jack socket (labelled 'line in'). This would normally be to connect to a guitar amplifier which has a high impedance 'line level' input socket. If you are using this output you may need to use a pre-amplifier to get a big enough signal for a microphone.
You can find the Shure SLX user manual here http://www.shure.com/idc/groups/public/documents/webcontent/us_pro_slx_en_ug.pdf
Jan 27, 2011 | Shure SLX1 Body-Pack Transmitter for...
Shorted out AC on Shure T4A receiver, need schematics
You can get the repair manuals/schematics by emailing Shure at service@shure.com
May 09, 2010 | Shure T4A DIVERSITY AC RECEIVER (CV) T4ACV...
Trying to use shure beta 87A with AT8801...getting no output. All connections tested and operational. Input to computer sound card or amp doesn't matter
Measure the voltage comming of pin2 and pin1, or between pin2 and pin3. If you donot get 48 volts the 8801 is bad. check your cable to make sure that pin2 and pin3 are not shorted. If you still have problems you can call Pro Line Music we ae a shure and at dealer. 215-736-8055
Dec 26, 2009 | Shure Beta 87A Professional Microphone
Remote microphone shure slx1 can't get enough volume I have control board maxed and I barely hear myself on speakers. the problem not in speakers or the sound board.the first time when I started getting...
1) Make certain the switch on the side of the SLX1 is set to "mic".
2) Make certain the output of the SLX4 receiver plugged into a microphone input, not a line input on your mixer.
Nov 16, 2009 | Shure SLX1 Body-Pack Transmitter for...
SHure SM57 mcorphone not working -wires disconnected
The wire coming from the switch if it has one will go to pin 2 as it is hot(+ve). Pin 3 is cold (-ve) and pin 1 is gound/shield which will make contact when the XLR connector is mounted back in the mike secured with the set screw. There should be a small hole in the side of the base of the mike that the set screw lines up with. Usind the correct size of flat bladed screw driver, back this screw out counter clockwise to secure the connector. If that is wrong, get back to me and i will hunt up my Shure wiring diagrams. If pin 2 and 3 are backwards the mike will be out of phase. Hope this helps.
Mar 30, 2009 | Shure SM57-LC Professional Microphone
Need cord for Shure 55S microphone
See the Shure website for the answer at:
http://shure.custhelp.com/cgi-bin/shure.cfg/php/enduser/std_adp.php?p_faqid=1012
Mar 09, 2009 | Shure 55SH Series II Professional...
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Shure SM2 Professional Headset Logo
254 people viewed this question
Top Shure Radio Communications Experts
eradiostore
eradiostore
Are you a Shure Radio Communication Expert? Answer questions, earn points and help others
