Question about SAMTRON 78DF 17" CRT Monitor
In my SAMTRON 56V monitor problem
After starting my monitor SAMTRON 56V there is a lighted line arises like tub light and it covers the area of START menu and some time more than START menu, so i face to proper site to START menu and other minimize item, So please give me an instruction what to do now?
My samtron 56v problem stand by when i power off yet i power on it is off position whats problem with me.switch is many time pressing then is on position.what is parts of my monitr suplly fault.wich part is spoil
Posted on Nov 07, 2011
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
I have samsung samtron 56v monitor and control lock appering on the screen. please tell me how to remove it from screen?
do it only if u r a professional..
the problem lies to a transistor near the osd ic(microprocessor), it is probably short....[refer the area around the front panel cn connector and the crystal clock generator]
Oct 18, 2009 | SAMTRON 55V 15" CRT Monitor
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
Control Lock Issue in Samtron 56V
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Jul 12, 2009 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor
HI all,
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
thanks a lot
Jan 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samtron 56v moniter on but wosulation not coming
samtron 56v monitor wosulation problem how can i sovle this problem
Sep 28, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
SAMSUNG 56V Monitor
If this behavior is relatively consistent, I would suspect the "mains capacitor", an electrolytic cap on the output of the AC bridge. If vibration affects behavior you may have cold solder joint(s) in the SMPS circuit. Knowing what current the monitor is drawing at turn on would be helpful.
Aug 13, 2006 | SAMTRON 55V 15" CRT Monitor
Open Questions:
SAMTRON 78DF 17" CRT Monitor Logo
427 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
