Question about Lands Phones
No dial tone. menu not working - Lands Phones
Is the soket in the wall plugged in riht
Posted on Jul 02, 2009
Gigaset AL110 REGISTERED , CANT DIAL OUT OR IN
Is there a dial tone? And have you tried another phone? If there is a dial tone make sure the phone is set for tone dialing. There will either be a switch on the side of phone for pulse or tone, set for tone. or go into the menu and look for it there...
Apr 14, 2014 | Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
The tone on my 2 portable DECT 6.0 phones was somehow changed- now every time I dial, I get the old rotary sound and I can not access any menu options. Help, I use my phone for work and need it fixed! ...
Your phone is somehow set to pulse dialling and you need to change it to tone. Instructions are given below.
Of course if you can't select menu options this will not work so please explain why the menu options are not available - what happens when you select the menu softkey?
Dial mode
The dial mode is preset to tone. If you do not have touch tone service, you need to change the setting to pulse.
To change the setting:
Press the MENU softkey when the handset is not in use.
Press or to select SETTINGS, then press the SELECT softkey.
Press or to select Dial mode, then press the SELECT softkey.
Press or to choose Tone or Pulse. Press the SET softkey to save, or press the BACK softkey to exit to the previous menu.
Feb 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Cant get the phone off pulse when dialing model#EM6113-BK
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
Press the "Menu OK" button. Select BASE using "
May 30, 2010 | Emerson EMSEM2646WH Phone
I have a Emerson DECT 6.0 with 3 head sets and i cant get the dial tone back from pulse.
It was easy for my Emerson Dect 6.0 to be switched either rotary / pulse by just pressing the "FLASH" button for 3 seconds until it beeped. Problem solved.
Or if that doesn't work, you have to:
Tone/Pulse
• Press the MENU button. Select BASE using <FLASH - or - CID> and press the MENU button again.
• Using <FLASH - or - CID> select DIAL MODE and press the MENU button.
• Using <FLASH - or - CID> select TONE or PULSE and press the MENU button.
OR
Press and HOLD the "<FLASH" button for approximately 3 seconds. T (Tone) or P (Pulse) appears in the display.
Feb 12, 2010 | Uniden DECT 6.0 Cordless Telephone...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
May 11, 2009 | Uniden Cordless Phone
How can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
Jun 01, 2008 | Uniden 5.8GHz Dual Cordless Phone
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Mar 28, 2008 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
