Question about HP Pavilion dv6000t Notebook
HP DV6000 Won't Charge
My HP Pavilion DV6000 will not charge any more. It has been saying that it is plugged in and charging but it has been at 78% for the past 4 hours. Is there anything I can do, or do I need to buy a new battery?
    New Friend:
  • 47 Answers
The charging process is suspended temporarily because the battery has overheated. My brand new DV5 (3 weeks old) does the same, because it's really hot here.
Turn the laptop off and the battery should charge. Also, when you do not need the battery and are running off the mains, remove it from the laptop. Keeping a battery at 100% wears it 4 times faster than doing regular charge/discharge cycles.
Posted on Jul 02, 2009
My laptop is not charging. it says 0% available (plugged in, not charging) plz help i have a stock hp pavilion dv5
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 25, 2011 | HP Pavilion dv5-1138nr Notebook
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
Pavilion dv6000 when power button is pressed,
Have you tried to boot the laptop with the power cable connected? Is the charging indicator on when you connect it to the adapter? If the charging indicator does not light up, check if your adapter output and try booting it with the power cable connected.
Jun 19, 2009 | HP Pavilion dv6000t Notebook
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
Your battery is dead when it no longer will hold a charge. Replace your battery.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
Wont charge
check voltage with volt ohm meter , you probably need a new charger, ebay less than 30 bucks
Don
Apr 02, 2009 | HP Pavilion dv4000 Notebook
HP DV6000 Battery problem
Bring it back to the repair shop if it has still repair warranty. They should take care of it.
Dec 04, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000t Notebook Logo
377 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
