Question about Lexmark X342n All-In-One Laser Printer
Getting message "PC Life Warning" - Lexmark X342n All-In-One Laser Printer
  • 10,515 Answers
That warning most likely refers to the photoconductor. That type of error normally means it would need to be replaced.
Thanks.
Posted on Jul 02, 2009
2 Suggested Answers
  • 125 Answers
SOURCE: Yellow PC unit life warning
Hi:
From the ready menu scroll down and find the supplies menu. Under the supplies menu you will find the Replace Supplies Menu. Select it. Then scroll dyel to yel PC unit, select it and that will turn off the prompt.
Good Luck
Andrew
Posted on Jun 28, 2009
98 Oldsmobile Aurora There's a on my Dash it says information center and has the oil fuel speed all that it says low oil is there any way anybody knows how to reset that
Check your engine oil using the oil dipstick located on the engine - you need to add oil to the fill line as shown on the dipstick. You should have the oil replaced regularly (every 3-6 months) and keep your eye on the level if the engine is leaking oil underneath or burning a lot of it.
Mar 08, 2017 | Oldsmobile Cars & Trucks
What does PC life warning mean - message on Dell 2350dn?
it could be that the cartridge is nearing the end of its serviceable life, I assume PC stands for Printer Cartridge. You could try getting it serviced
Feb 12, 2015 | Dell Office Equipment & Supplies
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
What does a "K Drum Life" warning mean?
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
ecblank.gif C DRUM LIFE REMAINING nn% ecblank.gif M DRUM LIFE REMAINING nn% ecblank.gif Y DRUM LIFE REMAINING nn% ecblank.gif BELT LIFE REMAINING nn% ecblank.gif FUSER LIFE REMAINING nn% ecblank.gif K TONER REMAINING nn% ecblank.gif C TONER REMAINING nn% ecblank.gif M TONER REMAINING nn% ecblank.gif Y TONER REMAINING nn%
May 31, 2011 | OKI C3200n Led Printer
Replace pc unit problem on Lexmark W840 Laser Printer
Here is an excerpt I found from the W840 user manual. Looks like you need to change the photoconductor kit. Here is the link for the user manual: images.lexmark.com/publications/pdfs/w840/eng/ug.pdf
To ensure print quality and to avoid damage to the printer, the printer stops operating after the photoconductor kit has reached approximately 60,000 pages (Letter/A4). The message 84 Replace PC Unit is displayed when the printer reaches this point. If the Toner Alarm setting is set to Single or Continuous (default is Off), the printer automatically notifies you before the photoconductor reaches this point and displays the message 84 PC Unit Life Warning. To avoid having the printer stop operating, replace the photoconductor kit when you first receive the 84 PC Unit Life Warning message. Once the photoconductor kit has been replaced, normal printer operation resumes
Apr 11, 2011 | Lexmark W840 Laser Printer
Reset after oil change
AnswerEasy get an oil change at a garage and have them erase the code or do the oil change your self and then disconnect the neg battary terminal. Easier AnswerOn the console, where the oil change light is on, scroll through the items until you get to oil life. Once at oil life, hold the reset button and it will say Engin oil new? Press reset again and this should set you oil life back to 100% without needing to disconnect your battery
Complete Answer
1- Turn on the ignition without starting the car
2- You will get warning messages on the display (including the "change oil soon" or "oil change required" message) press reset for each warning till you get the Odometer displayed.
3- press the setup button until "press reset for system check" appears
4- hit the reset button (need to do this fairly quickly, if you end up back at the odometer go back to step 3)
5- the system will scroll through the different things that are wrong that it has detected, you should go to "oil life XX%, Hold Rest New" message first if nothing else more major has been detected. When on this message hold the reset down unit you get the message "if new oil hold reset".
6 - hold the reset down till the message "oil life set to 100%" appears (note have seen different wording in some models)
7 - system should scroll through any remaining messages and then return to the odometer reading
Switch the car off and on and confirm that the message does not reappear. Have seen some instances where will not reset, if so take to your dealer.
Read more: http://wiki.answers.com/Q/How_do_you_reset_the_'Change_Oil_Soon'_light_in_a_2002_Ford_Explorer_or_Mercury_Mountaineer#ixzz1GbI0wIQ9
Mar 14, 2011 | 2004 Mercury Mountaineer
Message on Dell 2330 printer PC Life warning
I think you probably need to run the printer on a USB hub, sounds to me like you lack the power to run so many USB devices.
Mar 11, 2010 | Dell (2333R) Motherboard
Clear fuser life warning C524
Replacing the fuser
When 80 Fuser life warning appears on the operator panel, replace the fuser soon. Make sure one is on order. See
Ordering a fuser for more information.
When 80 Replace Fuser appears on the operator panel, replace the fuser immediately.
......From the Lexmark users guide.....
Dec 23, 2009 | Lexmark C524 Laser Printer
How do I reset Oil Life warning Message
Turn ignition on,need not running.Hold the reset button in until oil life xxx% blinking ,let go the button.Then hold it in again until it shows oil life 100%.Done
Apr 27, 2009 | Honda Accord Cars & Trucks
Lexmark X342n All-In-One Laser Printer Logo
440 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
