Question about WYSE S10 (90210501) Network Terminal
How to set screen as background to wyse desktop
I would like to set the background to RDP in the wyse.
please give me any body reply
Thank you.
  • atreides2112 May 11, 2010
    I'm not entirely sure what you mean. Do you want to disable backgrounds?
3 Suggested Answers
SOURCE: I have a 3235le with wince 2.12. How can I upgrade the RDP client to 5.1 or 5.1+?
I tried to do the same thing but ran into the same problem - I gave up. However, I have been successful in loading RDP 5.1 onto a Wyse 8235LE. Works great with full resolution RDP sessions!
Posted on Sep 10, 2007
SOURCE: Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Posted on Oct 07, 2009
My wyse laptop turns on but my screen stays black
try undo things..if problem solved then,try use different cards
May 17, 2012 | WYSE Winterm V90LE Thin Client - Thin...
How do i connect this terminal to windows 2003 server please give me the settings
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Thankyou
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
May 05, 2010 | VXL Instruments Itona CE Windows CE VIA...
Ho do the wyse winterm s50 worck? and ho do i, or can i use the?
There is documentation available for free from the wyse website on the knowledgebase. This will detail the full usage of the S50.
It can be used as a local web terminal, or linked to an external server, via RDP (terminal services) or ICA (citrix).
The admin guide (from wyse.com) will help you figure this out :)
Mar 24, 2009 | WYSE Winterm S50 Network Terminal
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
I have Wyse V50L termimals that cannot connect to Terminal Server 2008. Connections from XP Remote Desktop Client work fine. The server is configured to not use Network Level Authentication. The...
Have you tried the latest V50L firmware version? There was a major revision lately?
http://www.wyse.com/serviceandsupport/support/downloads.asp
Oct 25, 2008 | WYSE Computers & Internet
Conection to Microsoft Windows 2003 server terminal server
G key reset the unit, or failing that, re-image the device, and then setup your RDP connection from the default desktop.
Jul 09, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Wyse S10 Power UP issue after hung-up.
pull out the power cord for 5 minutes than put back in and turn on
Jan 29, 2008 | WYSE S10 (90210501) Network Terminal
Sep 03, 2007 | WYSE Winterm 3235LE Network Terminal
WYSE S10 (90210501) Network Terminal Logo
571 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
