Question about Behringer Audio Players & Recorders
I have a Behringer Europower PMH 5000 powered mixer and the main channel is no longer working
  • 130 Answers
SOURCE: amp blown cant even find a fuse
All amps have fuses [multiples]. Check where the black wire line connects to the unit itself. Look carefully as it may be sealed within that connection. A small, sharp object may be used to pry it open [unplug unit prior]. Fuses are usually located on the PCB and although they may not resemble the "glass type" they also look like little resistors. A DVM is your best bet in which to troubleshoot this problem, otherwise you are just doing a simple visual with no true direction.
Even the main transformer (primary windings) are thermally fused. Using a meter, check the primary for an open as well as the secondary. Should you have an open on the trans, it will be a costly fix. All depends on what happened when the amp stopped working. Overdrive? Underdrive? lalalalala
Posted on Oct 15, 2008
  • 61 Answers
SOURCE: Have Beringer Europower PMH 1000
The clicking could be the protection relays kicking in and out.
Check your speaker cables for short circuits.
Also make sure that the load you are applying to it does not go below the minimum impedance which i believe is 4ohms on this unit.
Posted on Mar 28, 2009
SOURCE: Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
Posted on May 12, 2009
  • 5603 Answers
SOURCE: Behringer pmx 2000 missing knob
If the shaft broke, then you will have to replace the whole encoder for it. You cannot glue a shaft and expect it to hold.
Posted on Jul 28, 2009
M2Tech1
  • 313 Answers
SOURCE: hi there i have a behringer pmh 500 mixer. after
sometimes the cause can be heat build up caused by dust inside the unit if you disconnect from power then remove hte cover screws get a soft paint brush and dust of the fans and power boards dont use a vac with a metal handle or hose as this can cause a static charge on the board and damage components>hope this helps A
Posted on Oct 19, 2009
Effects not working on Behringer PMP4000 monitor
Normally, on mixers, Effects do NOT go to Monitors.
What you have to do is
(check if there is a control for "EFF to MON" before)....
*Make a cable bridge from EFF OUT to any channel of your inputs.
*Now you can send the EFX to monitors as you would any signal.
Be mostly happy....
May 16, 2015 | Behringer Pmp4000 Europower 1600-watt...
No sound coming out on both r and l channel
Oops! Smoke from on of those is not unusual, as behringer is notorious for bad solder joints and BAD Power supplies. Anyhow the amplifiers are "most likely" OK. but your powersupply is shot. My PMH 3000 did the exact same thing. And here is the bad news. Behringer is also notorious for the lack of assistance in case of problems and will advice you to have the unit repaired at an approved service point. If however you are ok with electronics you can have a go yourself, manuals are few and (very) far between. I have some diagrams and stuff, so if you need some sing out. I have 2, MX 3282A mixers, nothing but trouble! Sorry I can't help you any further, Good luck.
Aug 13, 2014 | Behringer Europower Pmp5000 Powered Mixer...
All light blinking
Fix the short. It appears the 15 neg supply supplies the LEDs. If you need the service manual try: http://www.eserviceinfo.com/index.php?what=search2&searchstring=behringer+pmh+3000
Jan 27, 2014 | Behringer PMH3000 - EuroPower 2 x 400W...
Monitors not audible with Behringer 1680S
Assuming you're trying to power the monitors from this unit as well as the mains.....Confirm that the amp switch is in the middle position which splits the internal amps....one for main and one for monitors. Output A would power the monitors.... B would power the mains.
Aug 26, 2012 | Behringer PMP1680S Europower 10-Channel...
.necesito un diagrama esquematico para europower MPX 5000
.necesito un diagrama esquematico para europower pmp5000 pmp6000
Jun 29, 2012 | Behringer Europower Pmp5000 Powered Mixer...
One side of my europower pmp 5000 is out, the other is fine.....what up?
What is up is one of the two power amps is blown... I know this problem... It is USUALLY the rearmost channel which goes to the left Speakon faacing the back. Weak insulation between layers of the multilayer circuit board arcs and fries three transistors and a diode and sometimes a few more components. It takes a lot of skill to restore the module and is beyond most repair shops. A whole new module costs about $155 from Full Compass. The amp is an HCA2400 module, but you MAY need the Behringer part number to order it from Full Compass. Also please read my tip on Fixya for PMP mixers regarding the hazard when using 1/4 inch plugs from the Speakon connectors... the Channel A sleeve is the "hot", not the tip and if you ground the sleeve, goodbye channel A...
Aug 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
268 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
