My panasonic KXDT346 works great but when i get customers calling in most of them sound really muffeld or sound like there mumbiling i was wondering if anyone knew how to turn up the volume on the phone speeker?
The rubber volume button on the outside of the phone adjusts both the ringer volume and the call volume, which is how loud a caller sounds when on a call. If you are not on a call, the volume button will adjust the ringer volume. To adjust the volume of a caller, you must adjust the volume while on that call.
To do this, while looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume.The inside screen will display the call volume level. You may also set the call on Speakerphone mode. If you have the Jitterbug J model, there should be a button labelled "SPKR" on the upper left corner of the keypad.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Hi, Sorry you are having problems,
If I understand you correctly, you have your headphones plugged into the MacBook and are expecting sound to come out of your speekers ?
Well, if that is the case, you must know that the mac will automatically cut the signal to the speekers as soon as headphones are connected.
Now if you are saying that you connected the headphones to test it and found that whe you changed the volume, you could hear the change on the headphones, but when you unplug your head phones, you do not notice any sound difference on the speakers.
SO let's say that is the problem. First thing to always do, of course, is a full shut down and a clean start up with no headphones installed. Once you have booted up, try it again....
If it still does not work, go into your sound preferece pane in the system preferences and change some of the settings, like muting the sound and clicking the button that allows for showing volume in menu bar, unclick options go into the tabs go clicking and unclicking things...
then quit and then go back into the sound preferences and set it the way you want, sometimes shaking it up a bit gets it back on track...
Good luck.
