Question about Maytag 24 in. PDB1420 Built-in Dishwasher
MDB6000AWW. I have to push on the door to keep the dw running.
I assume I need a new latch but which one? Handle, latch AND/OR Hook, latch AND/OR Door latch hook assy? THANK YOU!
  • 232 Answers
Check for broken spinng on hook assm
Posted on Jul 02, 2009
06bmw pass.side door will not catch when push close how can get it to close
If what your telling me is that the door will go up to the latch and close no farther, then the latch is closed on the door. Hold the door handle open and stick a screwdriver in the hook that goes around the door post pin/ring and pop it open. It's just a hook that needs to be in an open and ready to hook position. The door will now close and latch.
Dec 07, 2017 | Cars & Trucks
I have a 2005 mazda mpv the pasanger side sliding door does not latch it mooves freely it is manual
You need to see if the latch bar ( curved metal piece that holds onto the strike bolt ) is in the closed position - if so, you'll need a helper to open it. You should also check to see if it is lubricated, which can keep it from latching.
When you look into the latch assembly, you should see a clear pathway for the striker bolt to enter the assembly. If there is a bar ( or hook ) blocking it, then you can use a flat blade screwdriver to move it to the open position. Insert the screwdriver into the latch assembly where you can pry on the inside of the hook, using the body of the door for leverage. position your screwdriver and then have your helper pull ( or push ) the outside door button / handle as you apply a small amount of pressure to the inside of the hook - the hook should easily slide out of the way. If it is hard to move, you'll need to spray some lubrication into the latch assembly. You can buy a can of white lithium grease in a spray can that will do the job.
There is a certain angle you'll need to pry in to get the latch to open - you may need to place the blade of the screwdriver through the hook and on the outside edge of the door or outside edge of the latch assembly, then gently push the screwdriver handle towards the outside of the van as the handle/ button is used.
Hope this helps!!
Jan 25, 2014 | 2005 Mazda MPV
2008 GMC 2500 Cargo Van Dash keeps sayin lr door is open and it is not!!! Driving me crazy!!
the latch in the left rear door is either bad or stuck, open door, then with a screwdriver, rock latches in door to simulate closed. release with exterior handle. spray lubricant (WD40) into latches and continue to exercise the latch. if this quick fix does not work, then a new latch for this door may be needed.
DW Mylin
Nov 28, 2012 | 2008 GMC Savana
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Door on a driver side does not work I put a new door handle now it doesn't work?
Can't tell from the vid but you did hook up the rod from the handle to the latch mechanism, correct? There should be 3 different rods hooked to the latch, one for the lock, one for the inside handle and one for the outside handle. make sure the one for the outside is hooked up at both ends. Then disconnect the one going to the handle and try actuating the latch by pushing/pulling the rod. If you can't actuate it that way, the latch may be broken internally and will need to be replaced.
Oct 14, 2012 | Cars & Trucks
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
The rear latch/handle on our ford freestar 2005 came off in my hand. it looks fine. I can;.t open the rear latch now. I got inside the van and removed the little plastic cap/tab the sits directly behind...
Here's how I repaired mine. Go inside and remove the plastic 2" square plastic cover. By pushing on the lever inside this area, the latch will release. Push on the door at the same time, when the latch is pushed. With the door open, remove all four screws from the plastic panel. Now pry carefully the big plastic panel off the door. There are plastic snaps holding this on, all around the edges. Now there is another metal cover over the latch mechanism under this panel. Remove this. You now can see into the latch area and put the handle back into the slot where it came out of. You'll see that the ends of the handle can be put back on the round bar, but to hold them in place, I attached 2 nylon ties on one end. You can also purchase a metal push on retainer from the local hardware store. Mine has been repaired for 8 months and had no trouble. Ford used no retainer on these handles and after prolonged use, they bend and the handle can be pulled off. A twenty minute job. Your wife can even do it.
Fred C
Dec 31, 2010 | 2004 Ford Freestar
Will not start after closing door, can select but does nothing when you push start. Acts if it is a sensor in the handle/latch assembly.
Here is a post I just sent to someone having similar issues. I copied just part of my solution. Hope it is helpful.
That was not to total solution in our case. I ended up ordering and replacing the door switch (a black plastic piece that is what the metal latch on the machine is supposed to "hook" into.
Replacing it is fairly simple. I did shut the power off for this. This part is replaced by taking off your face plate which is secured bu screws inside of your DW door around the edge. You will see 4 screws to remove and it "snaps" out. At this point you can see the working relationship with the latch, the switch and the contacts on the switch that the door latch (metal part coming out of the top of the DW) after replacing this...try the process again and hopefully your issue will be solved. I had to remove my latch and bend it back to the original shape and mess around with a slight bend to make it latch and hit the contacts in the door latch.
Apr 12, 2010 | Dishwashers
Dish washer that does not pump out the water on it"s final cycle
I had this same problem and after having the repairman over to our house several times and having the circuit board changed, I figured it out on my own...
It turns out that the pressure created from the steam during the water heating stage (HO) was pushing on the door latch just enough to prevent the motor from running properly. Because the door wasn't latched completely, the water wouldn't drain and the dishwasher would go to the "Drying" cycle without ever pumping the water out of the basin.
I adjusted the levelling on the DW and that helped, but I'm still not sure that the problem is fixed. We may need a new latch assembly.
To test this, when the DW stops running at any time, push on the door. If the motor kicks back on, this is the problem.
Dec 27, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
146 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
