changed the battery on my 2008 dodge ram slt 1500, now tha radio doesnt work,what did I do
SOURCE: dodge ram 1500 the radio and dash lights are not working
did u look at the fuses under the hood there might be one there other than that sounds like you wiring went bad or the part of your switch is bad replace the switch
SOURCE: thermostat in 2001 dodge ram 1500
the thermostat is located where the upper radator hose comes off the engine there are two bolts or nuts remove hose and remove housing you will see the thermostat when you do clean old gasket material off block and reverse removal procedure
SOURCE: code p1389 on dodge ram 1500 slt 5.9 liter
The Auto Shutdown (ASD) Relay is designed to cut off your engine in case of an accident or rollover.
The PCM controls the ASD and I'm thinking that the new PCM isn't programmed properly.
This relay should be in the fuse box under your hood
