Paper Jam error will not reset after removing jammed paper
Canon imageCLASS multifunction printer/copier/fax
Model: F189402
  • wysz Jul 02, 2009
    Thanks very much, 1alexh! I greatly appreciate your detailed explanation and the advice that fixed the problem =)
    Regards,
    Jeff
  • 484 Answers
In many cases, you must use compressed air in a can, and blow out the insides of the printer. These printers use photoelectronic eye technology to tell you when there is no paper left, or other supplies are used up. But unless you clear that out by blowing air through and past those sensors, they do not reset. The paper dust continues to block the sensor which makes it report that there is no paper, that there is a paper jam, etc.
Try clearing it out that way.
-a.
Posted on Jul 02, 2009
How can i fix paper jam when no paper is seen
The paper jam may be in some inner part of the feed path. You may have to do some disassembly and use a bright light to find the jam then figure out a way to remove the material.
Jul 30, 2014 | Canon imageCLASS D-480 - 23 PPM...
Paper Jam on the Canon Imageclass MF6530
Make sure that there aren't any tiny pieces of paper stuck in any of the rollers or gears. This can cause that as well.
Dec 10, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
My canon copier D420 had a paper jam. can't get the copier to work now.
Try checking the paper path, there might be a broken or loose gear in there, a bent wire or stuck debris. If you done this and all seems ok but the error message keeps flashing, try to do a hard reset. That usually clears off error messages. If nothing happens, you might need to call a technician.
Feb 07, 2013 | Canon New Usa Imageclass D420 Laser...
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Paper jam message does not clear after paper jam has been removed
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
Jan 08, 2010 | Canon imageCLASS D480 Black and White...
There is a paper jam below the sliding lid -
I suggest opening the right cover to remove paper jammed internally. There is a lengthy document at Canon support for your model: (you need to input your problem into the search box - ie. "ERROR LCD: Paper Jam" and click Search button).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=9437
Dec 13, 2009 | Canon imageCLASS D760 All-In-One Laser...
Paper Jam Error but no paper is jammed
depnding on which way you removed original jam you could have left a very small peice behind at a sensor arm, inspect very carfully at and before where the jam was
Mar 17, 2009 | Canon D320 imageCLASS Digital Copier
Jammed paper
u have remove toner form the printer then u can remove by hand
Jan 16, 2009 | Canon imageCLASS MF4690 Multifunction...
Paper jam
unplug printer from wall and plug back in somtimes this forces trapped paper out of machine as it wrams up.
also remove paper drawer to make sure paper isnt trapped in this area
Dec 06, 2007 | Canon imageCLASS D780 All-In-One Laser...
954 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
