Question about Roper MHE14XKB Microwave Oven
MICROWAVE I just bought a house that has a 6-month old Roper microwave. It has no power. I checked the electrical outlet and it works fine. I replaced the fuse but it still doesn't work. What else could be the problem?
  • Anonymous Jul 25, 2008
  • Roper Master
  • 9,098 Answers
First of all, it Roper may honor the warranty even though you're not the original owner. I'd contact them first:
If they won't cover it, here are some tips:
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
This last issue is what I suspect in your case.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
How to get full power from outlet???
If you are getting your microwave to turn on then you are just fine on your outlets. They should be putting out 120v. You just have an under powered Microwave.
Dec 14, 2015 | Microwave Ovens
Totally dead microwave
I'd first check the power outlet "under load". A hair dryer or a toaster make really good loads to test outlets.
Otherwise, at two months old, it should be under warranty and you should be able to get it fixed or replaced free.
Consult your owner's manual for the warranty and manufacturer contact info or contact the dealer you purchased it from for that info.
Dec 12, 2011 | GE Microwave Ovens
Purchased an MCO165UB microwave 7 months ago. Ran great for 6 1/2 months and then there was no power. No fan, no light, no cooking. It was like the cord was unplugged but the electrical outlet has...
I would have your house hold supply checked on the socket that it is plugged into. One appliance fail but not two.
I hope you find your fault.
Jan 25, 2011 | GE Microwave Ovens
GE JNM1851DM. only 6 months old and it is dead. Worked fine and then all of a sudden stopped working. The wall outlet has power so I know it is not a breaker in the house. Nothing works on the micro. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Sep 09, 2010 | GE Microwave Ovens
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
GE Sensor Microwave JES1855 died
Mine went dead after about 6 months. I had problems with my breakers and I found out that it was the microwave that blew all of them. I also found out that this perticular microwave is a fire hazard and should be recalled. It has caused me alot of headache. The breakers in my house are brand new and they are put out by GE also. It caused me to loose the food in my freezer, I did not know my freezer had lost power. It would cause my entire lights to go off and then they would come back on. I have checked around and I found out that the power cord on the back of the unit is very loose. I had a person to come in and look at it, he thinks its the power cord.
Feb 20, 2009 | GE JES1855 Microwave Oven
No Power at all
If it came installed in the house, it may have its own breaker switch. I'd check the breaker. Have any outlets in the kitchen gone out as well? This would support the breaker switch idea.
Hope this helps.
Jan 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
RCA Microwave stopped working
it probably just died they do that sometimes. you could take it back to the store you bought it, contact RCA or just throw it out and replace it with another.
Jan 26, 2008 | RCA RMW729 Microwave Oven
Emerson MW 8115SS
There is a 20 amp replaceable fuse inside the cabinet next to the power cord
Aug 17, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Roper MHE14XKB Microwave Oven Logo
97 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Mark Cheong
Mark Cheong
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
