Question about HP G60 Notebook
I have problem with opening my DVD R/W in HP G6000 note book. I tried manual method also , but it doesn't work. please help me
    Problem Solver:
  • 5 Answers
Make Sure that the Dvd R/w is working Correctly with the Correct Drivers Installed .Also Try Updating the Driver Installation.
Posted on Jul 02, 2009
  • Tercogen Jul 02, 2009
I have a HP dvd/cd rom rw 1040d disc drive. The disc tray doesn't open when empty. It tries to open but doesn't manage to open. If I manage to get it open, (Usually manually when shut off, it will open...
Premature failure of this drive appears to be a widespread issue. I have joined in a support thread at HP and encourage you to do the same:
http://h30434.www3.hp.com/t5/CD-DVD/Hp-dvd-1040i-Disk-tray-doesn-t-open-half-the-time/m-p/347544#M1980
Sep 29, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
MY dvd writer in my HP compaq pc willnot open even tried the pin in hole method system properties tell me it's working properly it tries to open but will not
Using the pin in hole method will open the tray, but you must use a strong paperclip and you have to push HARD, because it will be very stiff the first time this method is used.
Regards Bill
Mar 12, 2010 | Computers & Internet
HP G6000 laptop wont start
Extract your battery from your laptop for 12 min, then start your computer using your power cable (don't use your battery), if not try pressing F2 rapidly when opening, after you open your operating system try changing your graphics card drivers.
Jan 31, 2010 | HP Pavilion dv6000z Notebook
HP G6000 Optical Disk Drive malfunction
It sounds like you have done just about everything. The only thing you might do is try a CD cleaning disc (which has fine bristles to clean the optic sensor). Other than that, you've been very thorough and probably should think about replacing the drive. Hope this helps, Best Regards, -md
Nov 14, 2009 | Computers & Internet
Stuck DVD tray
Turn off the computer and then use the paper clip to open the DVD tray.
If this doesn't work, then something is jaming and stopping the tray from opening. In this case, remove the DVD drive and dismantle the drive (ie. remove the metal cover to reveal the internal components and remove the CD ot DVD disc.
If nothing works the the DVD drive is faulty and needs to be replaced, these drives are not expensive.
Jul 21, 2009 | HP Pavilion DV5234US Notebook Laptop
The tray on my Phillips DVDR 3380 won't open. It says blocked or no disc. I have pressed open /close many times but to no avail.I have turned the power off, makes no difference. I have press stop when it...
I have the same problem. What I do is push my hand down firmly on top of the DVD Recorder above the tray and while doing this press the open button. If this doesn't work get a screwdriver and poke it into the sides of the tray and pull it away. I find that the first method works best! XD
Hope This Helps!
Jul 04, 2009 | Philips DVDR3380/05 DVD Recorder
Dvd cd rom doesn't work
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
That should do it for you, good luck
please leave a rating, thankyou kindly
Apr 28, 2009 | Computers & Internet
How do you open the casing on the HP G6000 (laptop). My wireless is not working I believe there is a fault with the switch. The only areas i can get into is the ram and the hard drive.
h10032.www1.hp.com/ctg/Manual/c01095493.pdf
This is the disassembly instructions straight from Hewelett Packard. Just click the link above and it will either automatically download the PDF or open in your browser. I hope this helps.
Mar 25, 2009 | Computers & Internet
HP G60 Notebook Logo
128 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
