Question about Frigidaire FEB27S6DC / FEB27S7DC Electric Single Oven
F7 frigidaire can you tell me whats wrong f7 flashing
  • 232 Answers
Try turning the power to it off for an hour sometimes they get a glitch
Posted on Jul 02, 2009
  • 10,515 Answers
F7 is a EOC(electronic oven/clock control) failure.
Replace and it would fix the problem.
Note :- Some models have 3 to 5 years warranty.
Thanks.
Frigidaire plef398acb error code f7
Error F7 is a bad control board. It has to be replaced.
Jan 06, 2012 | Ovens
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
Flashing f7
Hi
Error code F7 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Frigidaire Ovens
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
http://www.applianceaid.com/fault_codes.html
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire cplef398ccb Flashing F7
I would replace the EDC
Feb 01, 2009 | Ovens
F7 screens flash and beep,but not every time we use range
There's a lot of info missing here, but any tech should be able to tell you what the F7 indicates. Each F code indicates a specific problem. In my case, an F-1 indication which says the circuit board has a problem, was resolved easily by fixing a problem with the momentary contact convection oven switch. You may have a faulty switch like that which could be causing the problem--in all likelihood, it was NOT a circuit board problem. If it was, then it was caused by another problem somewhere else, and they owe you a new circuit board, and a repair on whatever is causing the circuit board to fail. But more than likely they owe you a refund for the board you bought, and a fix on whatever is causing the problem....
Jan 29, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
hutchipop@yahoo.com
Regards,
Powerman
Mar 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Open Questions:
Frigidaire FEB27S6DC / FEB27S7DC Electric Single Oven Logo
265 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
