Question about Orion Televison & Video
Connect to dvd
Hello I have the orion tv model number tv1926aw- and wondering how I get to connect it to my dvd player. There is only one place to connect to on the TV and it says antenna
Thank you
ariellestein@gmail.com
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
In order to connect a dvd player to the TV you'll have to purchase a device called an RF modulator. You can find one at Wal-Mart, Target, Radio Shack, just to name a few. The purpose of this device is to allow you to connect a unit with composite outputs (yellow, red, and white) to a TV that only has a cable connector.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 02, 2009
How do i connect Orion DVD Player to LG Television with out a remote control.
The best option would be the HDMI-to-HDMI connection between your player and your TV. But because you mentioned that your TV is an old model, probably it does not have an HDMI port, in which case you have to use the RCA A/V connection. I understand you do not have a remote control for your TV, but you do not program a TV channel to watch DVD movies; you just switch between your TV and the DVD player as your audio/video sources. Here is what you have to do: check on your TV box for a button labeled 'Source' or 'Input'. Press on the button and it will alternate between TV and DVD (assuming you do not have any other device hooked up to your TV).
Dec 17, 2014 | Orion BDP3959 Player
Tip
Orion DVD-2000 Region Free Fix
Orion DVD-2000 DVD Player Region Free Fix
Would you like to unlock your Orion DVD-2000 DVD Player to Region Free?
Follow these steps to unlock your Orion DVD-2000 DVD Player :
  1. Power on your machine.
  2. Hold the Stop, Open/Close, Skip Forward and Skip Backward buttons simultaneously for 3 seconds.
  3. A 'hidden' menu will appear.
  4. Release the Stop, Open/Close, Skip Forward and Skip Backward buttons on your player.
  5. Select Region Number from the hidden menu and choose the Free option.
  6. Exit the menu.
Your Orion DVD-2000 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
Cant figure out which cables to plug into which holes. only have red,yellow & white cables. have a plug-in for coaxial (orange)-do i need a coaxial cable. have an Orion tv w/a dvd player in it-but it...
rca video out on DVD player toshiba SD3960 av in on tv
yellow is video part of rca
red and white is audio cable part of rca
change input source to AV 1 on tv when wacthing dvd player
for a more detailed explanation a photo of back of dvd player and model number of TV would be helpful
Mar 05, 2018 | Toshiba DVD Player
Hello, we have an Orion DVD/TV combo and have no remote for it. Is there any way to play a DVD without the remote the Play button alone on the unit does not play the DVD from its menu? We live in...
You should be able to do a channel search and come across the inputs either at the upper end or the lower end of the channel search. Using the channels on the TV itself, not cable or satellite, scroll through the channels until the desired input is found. Once on the desired input open the DVD player and insert a DVD and close the drawer. The DVD should start to play automatically. When it gets to the place on the DVD to actually "play movie" press the select/enter button on the remote. As for the replacement remote I would get a universal remote. They are far fairer in price than an original replacement remote and every bit as reliable. Just make sure to take the model of your TV/DVD player with you to make sure the remote you purchase is compatible. You probably need to go no further than your local hardware store or department store. Save on the shipping too. However if you are set on getting the original remote here is a place http://www.orion.newremotecontrol.com/catalog_item.php?catnum=076R0DT090 they also sell a few generic remotes for a few dollars less.
Regards, Tony
Apr 17, 2011 | Orion TVDVD091 9 in. TV/DVD Combo
Orion Orion1934 19" TV When I
if you are conncting it over component cable check your cables in the right spots if rca *red yellow nad white) then the cables may be bad or the refresh rate needs to be changed make sure the dvd player is selecting the correct output you are using.
Mar 16, 2011 | Orion1934 19" TV
I have a 36" insignia tv and just bought a sony dvd player and in the user manual for the dvd player there is no code for the remote for an insignia tv which i find wierd seeing as insignia is made by sony...
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
Jun 07, 2010 | Sony DVP-NS55P DVD Player
Orion tv without input/output plugs
from the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Jul 01, 2009 | Orion1934 19" TV
Hook up DVD
I hooked up my DVD player to the Yellow/Red/White inputs on the back of the set. I think you can buy a manual for $2.60 from the Orion website. Good luck.
Jan 05, 2009 | Orion STV2763 27" TV
RCR451
Orion TV; 1030, 1035, 1191.
Emerson VCR/DVD; 2142/3391, 2148/3403.
Dec 16, 2008 | RCA Universal Remote Control
Hooking up Dvd to TV
Buy an RF adapter for 30.00. It takes cable in and dvd and
has one output to tv.When you play DVD's it auto switches!!
Saves alot of good tv's.........T.
Oct 25, 2007 | Orion STV2763 27" TV
Televison & Video Logo
66 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
