Question about MSI AMD ATHLON-64 939 PIN MOTHER BOARD (MBK8TNEO2939) Motherboard
Motherboard problem Gd mng. Is ADM Athlon accept MSI Drives...? I want Audio pin download for ADM Antholn(tm)
Amd sempron (tm) processor 2800 1.6ghz sound drives
Please include the model number of your computer or motherboard. Audio is not included in processor.
Jul 07, 2014 | Computers & Internet
What is the Front Side Bus speed of MSI MS-7312 ver 1.0 motherboard
MOBOT Motherboard Spec Sheet MSI K9MM MS 7312 Motherboards org
THE LINK ABOVE GIVES THE SPECS
MSI K9MM-V (MS-7312) Spec Sheet Powered by MOBOT 10428.jpg Part Number K9MM-V (MS-7312) Manufacturer MSI Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset VIA K8M800 VT8237R+ North Bridge VIA K8M800 Socket Socket AM2 (940) Processor Types Athlon 64X2, Athlon 64FX, Athlon 64 Number of CPUs Front Side Bus 800MHz HyperTransport Bus Link Memory Type DDR Memory Channels Dual Maximum Memory 2GB External Graphics AGP8X IGP VIA UniChrome Pro South Bridge VIA VT8237R+ Audio 6-channel IDE SCSI None SATA 1.5 GB/s RAID LAN Firewire None USB USB 2.0 Expansion Slots BIOS AWARD Form Factor microATX
Jun 05, 2014 | MSI K9MM-V Motherboard
I have lost my driver CD. After re-installing Windows XP sound drivers are missing. I want to down load Audio drivers for AMD Athlon(tm) xp200+ 1.66 Ghz , 256 Ram motherboard
You can download the device drivers for your computer from the motherboard manufacturer's WEB site.
I cannot give you the link to the motherboard manufacturer's WEB site because youhave not provided me with the details of the make and model of your motherboard.
Apr 25, 2011 | AMD Athlon XP 2000+, 1.67 GHz Retail...
I loss my motherboard cd. the processor is adm athlon(tm)2800 processor. so i want to download from net. give me the web information of it
The info you gave is inaduaquate to locate any drivers for your motherboard. The CPU info is not enough to find any drivers for the motherboard.
You have to give the model/brand or name of the motherboard before FixYa can help.
Aug 21, 2010 | Computers & Internet
What kind of processor is capatable with km2m motherboard
Here is MSI's list:
http://us.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=527#menu
Apr 10, 2010 | MSI KM2M Combo-L (MS-6738-010) Motherboard
MSi Motherboard suddenly stopped seeing My IDE drives/ CD/DVD
Could quite simply be that its the IDE plug on the motherboard that's gone. If that's the case, you'll probably need a new motherboard.
As far as I can see, you've done pretty much everything that can be done to make sure it's not the motherboard.
Good Luck
Sep 23, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
I have lost my motherboard driver CD( AMD Athlon(tm)xp 2000+ 1.68 GHz,),from where i can download?. plz help?
If your motherboard is ASUS then you can go directly to www.asus.com and search for the k8mv motherboard drivers or
if its a MSI board the go to www.msi.com
May 15, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Fastest CPU available for the K7N2G?
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Mar 29, 2008 | MSI K7N2G-L Motherboard
MOTHERBOARD UPGRADE
1 yes,
2 buy a new board and chip, trust me spend as much as you can and as much memory as you can afford and laugh at the snails pace of your old system
Nov 05, 2007 | MSI KM4M-L Motherboard
MSI AMD ATHLON-64 939 PIN MOTHER BOARD (MBK8TNEO2939) Motherboard Logo
142 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
